Home » Language IDEs » PHP Development Tools (PDT) » help getting around bug in indigo(php comparison bug very annoying)
help getting around bug in indigo [message #702255] Tue, 26 July 2011 02:42 Go to next message
there is a bug logged for changes in the php compare window here:
( org.eclipse.php.internal.ui.compare.PhpMergeViewer cannot be cast to
org.eclipse.compare.contentmergeviewer.ContentMergeViewer )
https://bugs.eclipse.org/bugs/show_bug.cgi?id=330672
basically in eclipse indigo the compare window is broken, when you make changes in one of the comparisons there is no way to know whether it saved or not, sometimes it gives an error sometimes it doesnt
Can any Guru give me a hint on how to temp fix this or revert this functionality from a previous version or something?
It is causing me a lot of grief as i dont know if changes i make to a file in a comparison save or not..
Re: help getting around bug in indigo [message #702514 is a reply to message #702255] Tue, 26 July 2011 09:25 Go to previous messageGo to next message
Maybe the combination of Eclipse 3.6.2, WTP 3.3.0, DLTK 3.0 and PDT 3.0 works well.
I don't know whether this combination has other new problems though.
Re: help getting around bug in indigo [message #703043 is a reply to message #702514] Wed, 27 July 2011 01:03 Go to previous messageGo to next message
I will revert to helios 3.6
Re: help getting around bug in indigo [message #711043 is a reply to message #703043] Fri, 05 August 2011 13:39 Go to previous messageGo to next message
On 7/27/2011 1:03 AM, Ben K wrote:
Bear in mind that, in general, there are no more bug fix releases
scheduled on top of Helios. With few exceptions, any fixes going
forward will only be done for Indigo.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: help getting around bug in indigo [message #722852 is a reply to message #702255] Tue, 06 September 2011 19:37 Go to previous messageGo to next message
is now fixed, could someone be so kind as to help me with updating to the bugfix release?
just hitting update software doesnt find any updates on my indigo install
Re: help getting around bug in indigo [message #722866 is a reply to message #722852] Tue, 06 September 2011 22:15 Go to previous messageGo to next message
It seems not fixed.
Zend doesn't provide any updates but You can try nightly build with new installation of Indigo. (Do not touch your current installation/workspace)
https://hudson.eclipse.org/hudson/job/cbi-pdt-3.0-indigo/
https://hudson.eclipse.org/hudson/job/cbi-pdt-3.0-indigo/196/artifact/build/N201108100912/pdt-Update-N201108100912.zip
0. Download pdt-Update-N201108100912.zip
1. Install Eclipse SDK(Indigo) and create new workspace
2. Add pdt-Update-N201108100912.zip to update-site
3. Install pdt from pdt-Update-N201108100912.zip
My experience
1. Create php project, create php files test1.php and test2.php, and edit them
2. Select test1.php and test2.php>right-click>Compare With>Each Other
3. Edit test1.php
=> Dirty flag ('*') is OK
4. Close compare editor
=> Dialog asking for save test1.php pops up [OK]
5. Click Yes
=> Blank dialog (no title, no message, yes/no buttons) pops up [NG]
6. Open test1.php
=> Changes are *not* saved [*NG*]
Manual saving before closing editor is OK.
3. Edit test1.php
4. Save(Ctrl+S) test1.php
5. Close compare editor
6. Open test1.php
=> Changes are saved normally
bugs parade must go on...
Re: help getting around bug in indigo [message #722867 is a reply to message #722866] Tue, 06 September 2011 22:20 Go to previous messageGo to next message
ah well was worth a try, thank you for your time.
my helios install is actually quite stable now I might as well stick with that for the time being.
Re: help getting around bug in indigo [message #725594 is a reply to message #702255] Thu, 15 September 2011 05:59 Go to previous messageGo to next message
My best. Improved the compare editor.
http://sourceforge.jp/projects/pdt-tools/releases/52416
pdt_tools.feature_patch.pdt.3.0.0.v20110915.zip
Re: help getting around bug in indigo [message #741196 is a reply to message #725594] Wed, 19 October 2011 05:30 Go to previous message
Toshihiro Izumi wrote on Thu, 15 September 2011 05:59
Download Error - File Not Found
Where can I download file pdt_tools.feature_patch.pdt.3.0.0.v20110915.zip?
Previous Topic:Make eclipse interpret as javascript
Next Topic:PHP - Java
Current Time: Sat Jul 19 21:17:29 EDT 2025
Powered by FUDForum. Page generated in 0.05512 seconds
