Home » Eclipse Projects » Virgo » Correct way to deploy configuration artifacts from tooling
Correct way to deploy configuration artifacts from tooling [message #722583] Tue, 06 September 2011 05:10 Go to next message
Is it possible to deploy configuration artifacts to servers from tooling? If yes, how?
Re: Correct way to deploy configuration artifacts from tooling [message #722653 is a reply to message #722583] Tue, 06 September 2011 08:37 Go to previous messageGo to next message
I'm afraid not, we would like to in the future but it is not support right now.
Chris.
Re: Correct way to deploy configuration artifacts from tooling [message #723426 is a reply to message #722583] Thu, 08 September 2011 10:22 Go to previous messageGo to next message
Just mentioning this in case you're not aware of it; there is a Deployer interface accessible via JMX. For example, the code below allows you to deploy for example a WAR file, without needing access to the ApplicationDeployer interface.
	private void deployViaJMX(File file) {
		final String objectNameStr = "org.eclipse.virgo.kernel:category=Control,type=Deployer";
		final String operationName = "deploy";
		final String pathToFile = "file://" + file.getAbsolutePath();
		try {
			final ObjectName objectName = new ObjectName(objectNameStr);
			final boolean recoverOnStartup = false;  // would need to guarantee the File would exist on restart..
			Object result = mbeanConnection.invoke(objectName,
					operationName,
					new Object[] { pathToFile, recoverOnStartup },
					new String[] { String.class.getName(), boolean.class.getName() } );
			// (CompositeData)result; // gives symbolicName, type, version of app deployed
		} catch (InstanceNotFoundException noMBeanInstanceFound) {
			System.err.println("ERROR: Could not find MBean with name "
					+ objectNameStr + " in MBeanServer:\n"
					+ noMBeanInstanceFound.getMessage());
		} catch (MBeanException mbeanEx) {
			System.err.println("ERROR: Exception encountered on invoked MBean:\n" + mbeanEx.getMessage());
		} catch (ReflectionException reflectionEx) {
			System.err.println("ERROR trying to reflectively invoke remote MBean:\n" + reflectionEx.getMessage());
		} catch (Exception ex)  {
			System.err.println("ERROR trying to communicate with remote MBeanServer:\n" + ex.getMessage());
[Updated on: Thu, 08 September 2011 10:25] by Moderator
Re: Correct way to deploy configuration artifacts from tooling [message #725181 is a reply to message #723426] Wed, 14 September 2011 03:23 Go to previous message
I've filed an enhancement request: https://bugs.eclipse.org/bugs/show_bug.cgi?id=357595
Previous Topic:VTS 3.0 can't resolve constraint satisfied by a package in /repository/usr
Next Topic:ClassNotFoundException for an exported class
Current Time: Sat Jul 19 18:10:58 EDT 2025
Powered by FUDForum. Page generated in 0.03776 seconds
