Home » Modeling » TMF (Xtext) » Block scope, validation, linking and content assist
Block scope, validation, linking and content assist [message #722326] |
Mon, 05 September 2011 07:42  |
First I would like to say I agree with Ed: "Xtext is the coolest of the cool projects at Eclipse today"
I am trying to model a language that has the concept of block scopes. A block is created with { and }. This means that a variable is only accessible within the current block.
I have made a simplified example with only variable declarations and variable references. The grammar (I had to remove http because it's my first post):
grammar ee.xtext.test.Test with org.eclipse.xtext.common.Terminals
generate test "www.xtext.ee/test/Test"
File:
(expressions+=BlockExpression)+
Expression:
VariableDeclarations | FeatureCall | BlockExpression
BlockExpression returns Expression:
{BlockExpression}
(expressions+=Expression)+
VariableDeclarations returns Expression:
{VariableDeclarations}
'var' declarations+=VariableDeclaration (',' declarations+=VariableDeclaration)*;
VariableDeclaration:
{VariableDeclaration}
name=ID;
FeatureCall returns Expression:
{FeatureCall}
feature=[VariableDeclaration];
An example of the resulting language in an editor:
b //should not work
var a //declare a1 (gives an error on a)
a //refer to a1
var b, c //declare b1 and c1 (gives an error on c)
c //refer to c1
var c //declare c2 (gives an error on c)
a //refer to a1
b //refer to b1
c //refer to c2
var a //declare a2 (gives an error on a)
a //refer to a2
c //refer to c1
c //should not work
I have added comments to each line to specify what should happen. The following problems are in play:
1. Variables can be referenced when they are not declared yet
2. Variables can be referenced outside of block
3. Variables can not be declared with the same name in a different block
4. Variables do not reference the correct declaration
5. Content assist proposes variables in a sub block and variables that are not created yet (later in the document)
After searching these forums and various posts about scoping I was able to gather the following assumptions:
1. I am not completely sure how to solve it. My guess would be to create a validator that checks if a reference references a declaration earlier in the document.
2. If I am correct, this is caused by the lack of scoping. It seems I would need a custom scope provider that creates nested scopes for each block.
3. It seems this is caused by the NamesAreUniqueValidator. From what I have gathered it does not take scoping into account. This means I would need to create a custom NamesAreUniqueValidator that does take scoping into account.
4. I don't know how to solve this
5. Part of this will be solved by scoping (see 2) as it reduces the available variables. As for referencing variables that are not declared yet, I think this can be solved with a custom ProposalProvider.
I wonder if the above assumptions are correct and if anyone can help me fill in the blanks. If I have missed available implementations I would love to hear about them.
Thank you
[Updated on: Mon, 05 September 2011 07:44] by Moderator
Re: Block scope, validation, linking and content assist [message #722468 is a reply to message #722428] |
Mon, 05 September 2011 17:39   |
I have tried to implement scoping like this:
public class TestScopeProvider extends AbstractDeclarativeScopeProvider {
public IScope scope_FeatureCall_feature(BlockExpression context, EReference reference)
IScope parentScope = getParentScopes(context);
// problem, no current location available
List<VariableDeclaration> elements = getVariableDeclarations(null, context);
return Scopes.scopeFor(elements, parentScope);
public IScope scope_FeatureCall_feature(FeatureCall context, EReference reference)
BlockExpression block = (BlockExpression) context.eContainer();
IScope parentScope = getParentScopes(block);
List<VariableDeclaration> elements = getVariableDeclarations(context, block);
private IScope getParentScopes(BlockExpression block) {
EObject container = block.eContainer();
if (container instanceof BlockExpression)
BlockExpression parentBlock = (BlockExpression) container;
IScope parentScope = getParentScopes(parentBlock);
List<VariableDeclaration> elements = getVariableDeclarations(block, parentBlock);
} else
return IScope.NULLSCOPE;
private List<VariableDeclaration> getVariableDeclarations(EObject context, BlockExpression block) {
EList<Expression> expressions = block.getExpressions();
int index = context == null ? expressions.size() : expressions.indexOf(context);
List<VariableDeclaration> elements = Lists.newArrayList();
for (int i = 0; i < index; i++)
Expression expression = expressions.get(i);
if (expression instanceof VariableDeclarations)
elements.addAll(((VariableDeclarations) expression).getDeclarations());
return elements;
This indeed solves most of the problems. There however remains one problem, the second part of 5)
Quote:5. Content assist proposes variables in a sub block and variables that are not created yet
The problem of variables that are not created yet is apparent in the scope_FeatureCall_feature(BlockExpression context, EReference reference) method. The current position is unknown. I have looked at the Xbase implementation and it indeed manually calls the scope provider from a custom proposal provider.
Is there currently something implemented that allows me to know at what position the scope is requested from within the scope provider? Or should I mimic the Xbase implementation and manually retrieve the scope from a custom proposal provider?
Re: Block scope, validation, linking and content assist [message #722800 is a reply to message #722578] |
Tue, 06 September 2011 14:20   |
So far so good, I modified the scope provider in order to expose a method to get the scope:
public IScope getBlockExpressionScope(int index, BlockExpression context)
List<VariableDeclaration> elements = getVariableDeclarations(index, context.getExpressions());
int index = expressions.indexOf(context);
List<VariableDeclaration> elements = getVariableDeclarations(index, expressions);
EList<Expression> expressions = parentBlock.getExpressions();
int index = expressions.indexOf(block);
} else
private List<VariableDeclaration> getVariableDeclarations(int currentIndex, EList<Expression> expressions) {
for (int i = 0; i < currentIndex; i++)
return elements;
The proposal provider now looks like this:
public class TestProposalProvider extends AbstractTestProposalProvider {
@Inject
private ReferenceProposalCreator crossReferenceProposalCreator;
@Inject
private TestScopeProvider scopeProvider;
public void completeFeatureCall_Feature(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
CrossReference crossReference = (CrossReference) assignment.getTerminal();
ParserRule containingParserRule = GrammarUtil.containingParserRule(crossReference);
if (!GrammarUtil.isDatatypeRule(containingParserRule)) {
String ruleName = null;
if (crossReference.getTerminal() instanceof RuleCall) {
ruleName = ((RuleCall) crossReference.getTerminal()).getRule().getName();
EReference reference = GrammarUtil.getReference(crossReference);
EObject previousModel = context.getPreviousModel();
int index = -1;
if (!previousModel.equals(model))
//find the direct child of the model
while (!previousModel.eContainer().equals(model))
previousModel = previousModel.eContainer();
index = model.eContents().indexOf(previousModel);
IScope scope = scopeProvider.getBlockExpressionScope(index + 1, (BlockExpression) model);
crossReferenceProposalCreator.lookupCrossReference(scope, model, reference, acceptor, Predicates.<IEObjectDescription> alwaysTrue(), getProposalFactory(ruleName, context));
I couldn't help noticing the difference in the naming of the 'scope' and 'complete' methods. I would expect the complete method to be named 'complete_FeatureCall_feature' or the scope method to be named 'scopeFeatureCall_Feature'.
I will now dive into the NamesAreUniqueValidator.
Re: Block scope, validation, linking and content assist [message #741294 is a reply to message #740429] |
Wed, 19 October 2011 07:40   |
Hi, answers for my questions:
I found different solutions:
1°) With two IGlobalScopeProvider (one for validation, one for content assist)
Create a second IGlobalScopeProvider that extends an arbitrary interface such as IAlternateGlobalScopeProvider in order to bind it within modules.
When computing proposals for content assists, I get and cast the scope provider and call a specific method that will get the casted delegate on which I change the globalScopeProvider.
In this solution, the alternate global scope provider used by content assist lookup into all available files near the edited file.
The "normal" global scope provider only contains URI formally declared into the edited file. So validation, just see those ones.
2°) With predicate and a large IGlobalScopeProvider
When computing proposals for content assists, I get and cast the scope provider and call a specific method that will get the casted delegate on which I turn off a predicate.
This predicate check if external EObjects refers to an import that is formally declared.
For content assist proposal, the predicate is inactive.
3°) With a large IGlobalScopeProvider and a java validation
In this case, the linking validation won't fail so I check all imports are present at java validation time.
Don't hesitate to leave comments. I hope it might help someone.
Current Time: Sat Jul 19 21:15:35 EDT 2025
Powered by FUDForum. Page generated in 0.24965 seconds
