When Including JavaVMTypes MWE generates useless classes [message #722418] |
Mon, 05 September 2011 14:15  |
Hi there,
I have the following setup (actually I borrowed a lot of it from Xdoc, which is really great work!):
- A nice xtext grammar using JavaVMTypes (import "http://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes) and my own ecore-model
- When I generate using the genmodel, everything works, and I get my own classes generated right where they should and they reference the classes from org.eclipse.xtext.common.types
- Everything's fine
Then I try to run the mwe-workflow (code below), which actually works fine as well.
But, the result is that all classes from the JavaVMTypes get generated too (into emf-gen/types) and my own generated classes reference them instead of the org.eclipse.xtext.common.types.
Sorry, I just don't get it. Maybe somebody can help.
Best regards
Michael
module on.core.doc.xdoc.Xdoc
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "platform:/resource/on.core.doc.xdoc/src/on/core/doc/xdoc/Xdoc.xtext"
var file.extensions = "xdoc"
var projectName = "on.core.doc.xdoc"
var runtimeProject = "../${projectName}"
Workflow {
bean = StandaloneSetup {
platformUri = "${runtimeProject}/../.."
component = DirectoryCleaner {
directory = "${runtimeProject}/emf-gen"
component = org.eclipse.emf.mwe2.ecore.EcoreGenerator {
genModel = "platform:/resource/on.core.doc.xdoc/model/Xdoc.genmodel"
srcPath = "platform:/resource/on.core.doc.xdoc/src"
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}.ui/src-gen"
component = Generator {
pathRtProject = runtimeProject
pathUiProject = "${runtimeProject}.ui"
projectNameRt = projectName
projectNameUi = "${projectName}.ui"
language = {
uri = grammarURI
fileExtensions = file.extensions
fragment = grammarAccess.GrammarAccessFragment {}
// the serialization component
fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
fragment = resourceFactory.ResourceFactoryFragment {
fragment = parser.antlr.XtextAntlrGeneratorFragment {
// options = {
// backtrack = true
fragment = validation.JavaValidatorFragment {
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// registerForImportedPackages = true
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
fragment = types.TypesGeneratorFragment {}
fragment = formatting.FormatterFragment {}
fragment = labeling.LabelProviderFragment {}
fragment = outline.OutlineTreeProviderFragment {}
fragment = outline.QuickOutlineFragment {}
fragment = quickfix.QuickfixProviderFragment {}
fragment = contentAssist.JavaBasedContentAssistFragment {}
fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
fragment = generator.GeneratorFragment{}
Re: (no subject) [message #722427 is a reply to message #722420] |
Mon, 05 September 2011 14:34  |
thank you very much, now it works. Actually I had to add this:
scanClassPath=true
registerGenModelFile = "platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel"
Thank you Christian, again
Michael
FUDForum. Page generated in 0.03918 seconds
