Home » Eclipse Projects » EclipseLink » (no subject)
(no subject) [message #721778] Fri, 02 September 2011 16:11 Go to next message
Hi All,
i am using Eclipse Java EE IDE for Web Developers(Version: Indigo Release; Build id: 20110615-0604) which includes EclipseLink.
My Poject is working just fine in Eclipse, but i am not able to export it to a runnable jar. I always get Exceptions. Which JAR-Files i have to add to the classpath?
I dont understand the source of the problem. Could you give me a hint?
Matthias
The Exception is:
EntityManagerFactory creation failed.Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.3.0.v20110604-r9504
): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: java.net.URLCl
assLoader@d0a5d9
Internal Exception: Exception [EclipseLink-30009] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.pe
Exception Description: An exception was thrown while trying to load persistence unit at url: rsrc:../
Internal Exception: Exception [EclipseLink-30004] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.pe
Exception Description: An exception was thrown while processing persistence.xml from URL: rsrc:../
Internal Exception: java.net.MalformedURLException
Exception in thread "main" java.lang.reflect.InvocationTargetException
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Caused by: java.lang.ExceptionInInitializerError
at org.rogatio.database.PersistenceUtil.<clinit>(PersistenceUtil.java:30)
at org.rogatio.database.QuestionsDao.findQuestionIds(QuestionsDao.java:33)
at org.rogatio.wiki.WikiParser.removeQuestions(WikiParser.java:409)
at org.rogatio.wiki.WikiParser.parsePage(WikiParser.java:219)
at org.rogatio.model.Wiki.parse(Wiki.java:491)
at org.rogatio.main.PortableWiki.main(PortableWiki.java:246)
... 5 more
Caused by: Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence
assLoader@d0a5d9
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionSearchingForPersistenceResources(
PersistenceUnitLoadingException.java:126)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:115)
at javax.persistence.Persistence.createEntityManagerFactory(Unknown Source)
at org.rogatio.database.PersistenceUtil.<clinit>(PersistenceUtil.java:18)
... 10 more
Caused by: Exception [EclipseLink-30009] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionLoadingFromUrl(PersistenceUnitLoa
dingException.java:99)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processPersistenceArchive(Persistenc
eUnitProcessor.java:538)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.getPersistenceUnits(PersistenceUnitP
rocessor.java:444)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.findPersistenceUnitInfoInArchive(JPAInitialize
r.java:172)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.findPersistenceUnitInfoInArchives(JPAInitializ
er.java:154)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.findPersistenceUnitInfo(JPAInitializer.java:13
5)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:73)
... 13 more
Caused by: Exception [EclipseLink-30004] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionProcessingPersistenceXML(Persiste
nceUnitLoadingException.java:117)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processPersistenceXML(PersistenceUni
tProcessor.java:579)
eUnitProcessor.java:536)
... 18 more
Caused by: java.net.MalformedURLException
at java.net.URL.<init>(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
tProcessor.java:577)
... 19 more
(no subject) [message #722750 is a reply to message #721778] Tue, 06 September 2011 11:44 Go to previous message
Where are you putting your persistence.xml? Is it in your meta-inf directory?
Are you using OSGi? What environment are you using and how is your persistence.xml on your classpath?
Also include your persistence.xml, is its header valid?
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:PLSQLCollection example
Next Topic:Transaction Marked for Rollback -- No exceptions logged ?? possible bug?
Current Time: Sun Jul 20 17:18:47 EDT 2025
Powered by FUDForum. Page generated in 0.22760 seconds
