Home » Modeling » OCL » OCL for InstanceSpecifications on M1
OCL for InstanceSpecifications on M1 [message #721231] Thu, 01 September 2011 04:30 Go to next message
Hi all,
this might be a silly question, but I'm really not sure about the answer
(maybe I got something wrong when talking about instances at M1 level):
I need to create InstanceSpecifications of a particular classifier (mostly
signal and class) at M1 level. So I use the well-known InstanceSpecification
element provided by UML2 Superstructure for the in-model instantiation of
classifier.
Let's construct a simple example:
Class A{
+ attA : Integer [0..1]
Now, assume there some OCL constraints applied on the classifier for which I
have to create the InstanceSpecification like
context ClassA
inv attA: self.attA > 0 and self.attA <= 10
To check whether the constraint works, I create two InstanceSpecifications:
ins1:ClassA{
slot -> attA = LiteralInteger(value=-5)
insValid:ClassA{
slot -> attA = LiteralInteger(value=5)
Will the OCL engine complain about the first InstanceSpecification that do
not comply with the restriction given by the constraint? I have really no
idea whether the Eclipse OCL is aware of InstanceSpecification as in-model
instances at the same M-level (M1) where the defining context is located as
well.
Thanks for a nice answer.
Timothy
Re: OCL for InstanceSpecifications on M1 [message #721237 is a reply to message #721231] Thu, 01 September 2011 04:46 Go to previous messageGo to next message
It should work:
OCL doesn't really care about M levels. If classes have
constraints/expressions they can be exploited when validating/evaluating
instances.
But:
You are using UML, and it was only just before Indigo that I discovered
that the UML to Ecore conversion used a distinct EAnnotation source URI
to the Ecore delegates URI and so UML-derived Ecore did not validate. I
upgraded the OCL support for UML to translate the 'old' URI so that in
principle constraints defined in a UML meta-model could work for
instances of corresponding Ecore meta-model elements. I cannot say that
this has been very thoroughly tested. It's really all waiting till I
have time to enhance the OCLinEcore syntax sufficiently to justify the
rename to UnifiedOCL that supports either Ecore or UML meta-models. (The
OCLinEcore and Xtext OCL Console will already load a UML meta-model).
You may need to do a load and save of the UML-derived *.ecore file with
the Indigo OCLinEcore editor in order to get the translation that then
allows genmodel to work correctly.
Ed Willink
On 01/09/2011 09:30, Timothy Marc wrote:
> Hi all,
> answer (maybe I got something wrong when talking about instances at M1
> level):
> (mostly signal and class) at M1 level. So I use the well-known
> InstanceSpecification element provided by UML2 Superstructure for the
> in-model instantiation of classifier.
> Class A{
> which I have to create the InstanceSpecification like
> context ClassA
> ins1:ClassA{
> insValid:ClassA{
> that do not comply with the restriction given by the constraint? I
> have really no idea whether the Eclipse OCL is aware of
> InstanceSpecification as in-model instances at the same M-level (M1)
> where the defining context is located as well.
> Timothy
Re: OCL for InstanceSpecifications on M1 [message #722155 is a reply to message #721237] Sun, 04 September 2011 15:10 Go to previous messageGo to next message
Ed,
thanks for your answer.
>instances.
Well, that's indeed the theory and good if Eclipse OCL support this kind of
constraint checking. But I was not sure, since the UML InstanceSpecification
mechanism is sort of indirect instances (compared to the instance
specification of the M-levels), where the classifier of an instancespec is
directly defined via the classifier-association.
>that the UML to Ecore conversion used a distinct EAnnotation source URI to
>principle constraints defined in a UML meta-model could work for instances
>of corresponding Ecore meta-model elements. I cannot say that this has been
>very thoroughly tested. It's really all waiting till I have time to enhance
>the OCLinEcore syntax sufficiently to justify the rename to UnifiedOCL that
>supports either Ecore or UML meta-models. (The OCLinEcore and Xtext OCL
>Console will already load a UML meta-model). You may need to do a load and
>save of the UML-derived *.ecore file with the Indigo OCLinEcore editor in
>order to get the translation that then allows genmodel to work correctly.
I do not understand either the problem you described or/and the solution you
presented. All I want to do is to check whether a given UML
InstanceSpecifications comply with rules defined in an external OCL
document. Is this possible?
Timothy
"Ed Willink" schrieb im Newsbeitrag news:j3ng53$ieg$1@news.eclipse.org...
It should work:
instances.
But:
Ed Willink
> Hi all,
> Class A{
> context ClassA
> ins1:ClassA{
> insValid:ClassA{
> as well.
> Timothy
Re: OCL for InstanceSpecifications on M1 [message #722261 is a reply to message #722155] Mon, 05 September 2011 03:34 Go to previous messageGo to next message
I'm at a loss how to help, since you seem to be looking for problems
without understanding solutions and without presenting any candidate
executable solution for assessment.
As far as I can see, for you, an InstanceSpecification is just a
meta-model element with constraints that you wish to evaluate on a
model. So what is the problem? OCL supports constraints on meta-models.
It is not relevant whether InstanceSpecification is part of the UML or not.
Ed Willink
On 04/09/2011 20:10, Timothy Marc wrote:
> Ed,
>> validating/evaluating instances.
> kind of constraint checking. But I was not sure, since the UML
> InstanceSpecification mechanism is sort of indirect instances
> (compared to the instance specification of the M-levels), where the
> classifier of an instancespec is directly defined via the
>> discovered that the UML to Ecore conversion used a distinct
>> EAnnotation source URI to the Ecore delegates URI and so UML-derived
>> Ecore did not validate. I upgraded the OCL support for UML to
>> translate the 'old' URI so that in principle constraints defined in a
>> UML meta-model could work for instances of corresponding Ecore
>> meta-model elements. I cannot say that this has been very thoroughly
>> tested. It's really all waiting till I have time to enhance the
>> that supports either Ecore or UML meta-models. (The OCLinEcore and
>> Xtext OCL Console will already load a UML meta-model). You may need
>> to do a load and save of the UML-derived *.ecore file with the Indigo
>> OCLinEcore editor in order to get the translation that then allows
> solution you presented. All I want to do is to check whether a given
> UML InstanceSpecifications comply with rules defined in an external
> OCL document. Is this possible?
> Timothy
> Hi
> It should work:
> instances.
> But:
> Regards
> Ed Willink
>> Hi all,
>> M1 level):
>> Class A{
>> context ClassA
>> ins1:ClassA{
>> insValid:ClassA{
>> Timothy
Re: OCL for InstanceSpecifications on M1 [message #726685 is a reply to message #722155] Mon, 19 September 2011 04:47 Go to previous message
Hi Timothy,
there is no problem to do what you want. I use OCL in this way.
Hava a look at the following Code:
Helper helper = getOcl().createOCLHelper();
if (contextElement != null && contextElement instanceof
InstanceSpecification) {
helper.setInstanceContext(contextElement);
String oclCon="here your ocl constraint";
Constraint inv = helper.createInvariant(oclCon);
Query query = getOcl().createQuery(inv);
boolean result = query.check(contextElement);
Peter
Am So 04.09.11 21:10, schrieb Timothy Marc:
> Ed,
> InstanceSpecification mechanism is sort of indirect instances (compared
> to the instance specification of the M-levels), where the classifier of
> an instancespec is directly defined via the classifier-association.
>> Xtext OCL Console will already load a UML meta-model). You may need to
> you presented. All I want to do is to check whether a given UML
> Timothy
> Hi
> It should work:
> instances.
> But:
> Regards
> Ed Willink
>> Hi all,
>> level):
>> Class A{
>> context ClassA
>> ins1:ClassA{
>> insValid:ClassA{
>> Timothy
Previous Topic:Writing Inter Class constraints
Next Topic:[CompleteOCL] Accessing the metamodel
Current Time: Sun Jul 20 17:34:24 EDT 2025
Powered by FUDForum. Page generated in 0.05363 seconds
