Problem with transformation DSM2UML [message #72109] |
Wed, 16 January 2008 09:55  |
Originally posted by: amivi.fagbegnon.gmail.com
I have a problem to assign types to a UML Property. In fact I have a
model XMI conforms to meta model and I try to convert it into UML Model
(class diagram).
Thx
[ATL] Problem with transformation DSM2UML: UML type assignment [message #73138 is a reply to message #72132] |
Wed, 23 January 2008 05:25  |
ok,
I have a model xmi conforms to an ecore meta model. The meta model
define an enumeration types TYPE(varchar,char,time, nulmeric, float...).
I want to generate (with ATL Transformation) a UML class diagram
matching the xmi model. I have dificulties to match these
types(enumliteral) with UML primmitive types.
Indeed I want to have:
- a helper which gives UML!PrimitiveType according to the type of the
element in xmi model (char, int,varchar...);
- the correct method or instruction ATL that assign the type computed to
a UML property.
I hope that it's more clear...
Amivi
Quentin Glineur a écrit :
> fagbegnon a écrit :
>> Hello,
>> Model (class diagram).
>> Thx
> Can you be a little more specific on your problem (about you
> configuration, the way you are trying to make your conversion, etc) ?
> Quentin
FUDForum. Page generated in 0.04622 seconds
