Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse plugin problem(Can't access other plugin's exported packages)
Eclipse plugin problem [message #720838] Wed, 31 August 2011 06:30 Go to next message
I am developing an eclipse plugin, and I am trying to use Android's ddmlib, which is exported by the plugin: com.android.ide.eclipse.ddms .
The problem is: I added that plugin to the dependencies in the manifest, but when I try to use the classes contained in ddmlib jar, they aren't accessible. Only com.android.ide.* ones are.
Can anyone help?
Why can't I access the plugin's exported packages?
Re: Eclipse plugin problem [message #720949 is a reply to message #720838] Wed, 31 August 2011 10:30 Go to previous messageGo to next message
Please double check that the ddms bundle actually exports all of the packages you need.
Also, until 3.7, PDE did not support nested jars. If the ddms plug-in was jarred, PDE was unable to extract the jars and add them to the JDT classpath. This could be worked around by having the project in your workspace and is fixed in 3.7.
Re: Eclipse plugin problem [message #725395 is a reply to message #720949] Wed, 14 September 2011 12:27 Go to previous message
Installing Eclipse 3.7 solved the problem, thank you!
Previous Topic:Dependency problem on product export with 3.7
Next Topic:MultiEditor and Properties View problem
Current Time: Sun Jul 20 14:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.09735 seconds
