Home » Modeling » EMF » [CDO] Move operations make the moved element dirty
[CDO] Move operations make the moved element dirty [message #720747] Wed, 31 August 2011 03:29 Go to next message
Hi everyone !
When I move a CDOObject e1 from its container (c1) to a new container (c2) :
- c1 is modified (and revision is increased) : ok, we modify its
children list by removing e1
- the same for c2 : we modify its children list by adding e2
- what I don't get is why e1 is also modified : according to me,
CDOStoreImpl.setContainer() should not increase revision of the child,
as we do not modify its features.
Do you have any reason to do so ?
Here is a stack trace (from maintenance branch CDO 4.0) that shows that
e1 is considered as modified by the CDOStateMachine
     CDOStateMachine.writeWithoutViewLock(InternalCDOObject,
CDOFeatureDelta) line: 330
     CDOStateMachine.write(InternalCDOObject, CDOFeatureDelta) line: 321
     CDOStoreImpl.getRevisionForWriting(InternalCDOObject,
CDOFeatureDelta) line: 686
     CDOStoreImpl.setContainer(InternalEObject, CDOResource,
InternalEObject, int) line: 111
     WheelImpl(CDOObjectImpl).eBasicSetContainer(InternalEObject, int)
line: 1016
     WheelImpl(CDOObjectImpl).eBasicSetContainer(InternalEObject, int,
NotificationChain) line: 655
     WheelImpl(BasicEObjectImpl).eInverseAdd(InternalEObject, int,
Class<?>, NotificationChain) line: 1423
EStoreEObjectImpl$BasicEStoreEList<E>(DelegatingEcoreEList<E>).inverseAdd(E,
NotificationChain) line: 398
EStoreEObjectImpl$BasicEStoreEList<E>(DelegatingNotifyingListImpl<E>).addUnique(E)
line: 285
     EStoreEObjectImpl$BasicEStoreEList<E>(AbstractEList<E>).add(E)
line: 307
Thanks !
Alex
Re: [CDO] Move operations make the moved element dirty [message #720767 is a reply to message #720747] Wed, 31 August 2011 04:04 Go to previous messageGo to next message
Hi Alex,
The container is kind of a feature in CDO and its modification creates a CDOContainerFeatureDelta which definitely needs
to be stored.
Cheers
/Eike
http://www.esc-net.de
Am 31.08.2011 09:29, schrieb Alex Lagarde:
> Hi everyone !
> - c1 is modified (and revision is increased) : ok, we modify its children list by removing e1
> - what I don't get is why e1 is also modified : according to me, CDOStoreImpl.setContainer() should not increase
> revision of the child, as we do not modify its features.
> Here is a stack trace (from maintenance branch CDO 4.0) that shows that e1 is considered as modified by the
> CDOStateMachine
>     CDOStateMachine.writeWithoutViewLock(InternalCDOObject, CDOFeatureDelta) line: 330
>     CDOStoreImpl.getRevisionForWriting(InternalCDOObject, CDOFeatureDelta) line: 686
>     CDOStoreImpl.setContainer(InternalEObject, CDOResource, InternalEObject, int) line: 111
>     WheelImpl(CDOObjectImpl).eBasicSetContainer(InternalEObject, int) line: 1016
>     WheelImpl(CDOObjectImpl).eBasicSetContainer(InternalEObject, int, NotificationChain) line: 655
>     WheelImpl(BasicEObjectImpl).eInverseAdd(InternalEObject, int, Class<?>, NotificationChain) line: 1423
> EStoreEObjectImpl$BasicEStoreEList<E>(DelegatingEcoreEList<E>).inverseAdd(E, NotificationChain) line: 398
> EStoreEObjectImpl$BasicEStoreEList<E>(DelegatingNotifyingListImpl<E>).addUnique(E) line: 285
>     EStoreEObjectImpl$BasicEStoreEList<E>(AbstractEList<E>).add(E) line: 307
> Thanks !
> Alex
Re: [CDO] Move operations make the moved element dirty [message #720786 is a reply to message #720767] Wed, 31 August 2011 04:35 Go to previous message
Ok, well from an CDO-external viewpoint this seems a bit odd, but we
will do with this.
Thanks as usual for your fast reply :)
Alex
Previous Topic:[Compare] Differences found on identical xmi files
Next Topic:FeatureMap, SetCommand, and dynamic attributes
Current Time: Sun Jul 20 08:39:09 EDT 2025
Powered by FUDForum. Page generated in 0.17058 seconds
