Home » Archived » Buckminster » Buckminster seems to ignore component provider
Buckminster seems to ignore component provider [message #719806] Mon, 29 August 2011 01:05 Go to next message
I am running a build on build.eclipse.org for Texo which fails to get a dependency. Buckminster seems to ignore a
provider. Not sure if this is caused by Buckminster or by build.eclipse.org not allowing component providers on external
websites.
This is the buckminster output:
[java] WARNING [0029] : Component request
org.junit:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705] is inconflict with request
org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100]
[java] ERROR [0005] : No suitable provider for component com.mysql.jdbc:osgi.bundle/[5.0.0,6.0.0) was found in
resourceMap
file:/opt/users/hudsonbuild/workspace/emft-texo-nightly/org.eclipse.emf/org.eclipse.emf.texo/releng/org.eclipse.emf.texo.releng.buckminster/test/texo.rmap
searchPath updates.platform
[java] ERROR [0005] : Rejecting provider
p2(http://download.eclipse.org/eclipse/updates/3.7[http://download.eclipse.org/eclipse/updates/3.7]): No component match
was found
searchPath target.platform
p2(http://download.eclipse.org/releases/indigo[http://download.eclipse.org/releases/indigo]): No component match was found
p2(http://download.eclipse.org/tools/orbit/downloads/drops/R20100519200754/updateSite[http://download.eclipse.org/tools/orbit/downloads/drops/R20100519200754/updateSite]):
The target.platform however has three entries, the second entry (www.elver.org) seems to be ignore:
<searchPath name="target.platform">
<provider componentTypes="eclipse.feature,osgi.bundle" readerType="p2" source="false" mutable="false">
<uri format="http://download.eclipse.org/releases/indigo"/>
</provider>
<uri format="http://www.elver.org/eclipse/update"/>
</provider>
<provider readerType="p2" componentTypes="osgi.bundle" mutable="false" source="false">
<uri format="http://download.eclipse.org/tools/orbit/downloads/drops/R20100519200754/updateSite"/>
</provider>
</searchPath>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Buckminster seems to ignore component provider [message #719813 is a reply to message #719806] Mon, 29 August 2011 02:06 Go to previous messageGo to next message
Hi Martin,
No providers are ignored. It's just that none of them contains the 'com.mysql.jdbc' component. My guess is that it's
because mysql is GPL'ed. You won't find any GPL'ed material in a repository at Eclipse.org. Try maven central (see topic
"getting shiro with buckminster" for an example).
- thomas
On 2011-08-29 07:05, Martin Taal wrote:
> websites.
> resourceMap
> was found
> </provider>
> </provider>
> </provider>
> </searchPath>
Re: Buckminster seems to ignore component provider [message #719814 is a reply to message #719813] Mon, 29 August 2011 02:14 Go to previous messageGo to next message
Hmm, scratch that. I didn't see this provider:
</provider>
And you're right. This is probably some kind of access restriction. Perhaps the legacy update site converter quietly
swallows some important info. Have you tried running in debug mode? Do you have your proxies set up?
- thomas
On 2011-08-29 08:06, Thomas Hallgren wrote:
> Hi Martin,
> - thomas
>> Hi,
>> websites.
>> resourceMap
>> was found
>> found
>> </provider>
>> </provider>
>> </provider>
>> </searchPath>
Re: Buckminster seems to ignore component provider [message #719852 is a reply to message #719814] Mon, 29 August 2011 04:14 Go to previous messageGo to next message
I think this was an intermediate failure. Another change I did, the test launch config, I changed it from a junit launch
config to a 'junit plugin test' launch config. This did not seem to work (can not open launch config). When I moved back
to the straight junit launch config it worked fine.
Should junit plugin tests be launched differently?
This is the part of the build scripts that launched the launch config:
<buckminster command="junit" workspace="${workspacePath}">
<cmdargs>
<arg value="-l" />
<arg value="org.eclipse.emf.texo.test.all/TexoAllTests.launch" />
<arg value="-o" />
<arg value="${testResultsPath}/test-results-texo.xml" />
<arg value="--stdout" />
<arg value="${testResultsPath}/stdout.txt" />
<arg value="--stderr" />
<arg value="${testResultsPath}/stderr.txt" />
<arg value="--flatXML"/>
</cmdargs>
</buckminster>
gr. Martin
> </provider>
> - thomas
>> Hi Martin,
>> - thomas
>>> Hi,
>>> websites.
>>> resourceMap
>>> was found
>>> found
>>> </provider>
>>> </provider>
>>> </provider>
>>> </searchPath>
The Netherlands
Re: Buckminster seems to ignore component provider [message #719853 is a reply to message #719852] Mon, 29 August 2011 04:34 Go to previous messageGo to next message
We're executing 'junit plugin test' launch configs without problems. Do you see any problems in the log? I.e. in
<workspace>/.metadata/.log?
- thomas
> <cmdargs>
> <arg value="-l" />
> <arg value="-o" />
> </cmdargs>
> </buckminster>
> gr. Martin
>> </provider>
>> - thomas
>>> Hi Martin,
>>> - thomas
>>>> Hi,
>>>> external
>>>> websites.
>>>> resourceMap
>>>> match
>>>> was found
>>>> found
>>>> </provider>
>>>> </provider>
>>>> </provider>
>>>> </searchPath>
Re: Buckminster seems to ignore component provider [message #719909 is a reply to message #719853] Mon, 29 August 2011 08:29 Go to previous messageGo to next message
Yes I see unresolved dependencies, but I don't understand why they don't happen when I run 'non-plugin-mode'. The target
platform contains the correct plugins.As it works for me for now, it is not very critical.
But is there a difference in the way a normal junit is run or a junit plugin test is run? Difference in the way the
target platform is treated/used?
gr. Martin
> - thomas
>> <cmdargs>
>> <arg value="-l" />
>> <arg value="-o" />
>> </cmdargs>
>> </buckminster>
>> gr. Martin
>>> </provider>
>>> - thomas
>>>> Hi Martin,
>>>> topic
>>>> - thomas
>>>>> Hi,
>>>>> external
>>>>> websites.
>>>>> resourceMap
>>>>> match
>>>>> was found
>>>>> found
>>>>> </provider>
>>>>> </provider>
>>>>> </provider>
>>>>> </searchPath>
The Netherlands
Re: Buckminster seems to ignore component provider [message #719930 is a reply to message #719909] Mon, 29 August 2011 09:13 Go to previous message
Not to my knowledge, no. The latter needs more stuff in order to run so my guess is that something cannot be resolved,
perhaps transitively. You should be able to see what's missing in the log though.
- thomas
Previous Topic:Re: getting shiro with buckminster
Next Topic:External component repository
Current Time: Sun Jul 20 01:20:47 EDT 2025
Powered by FUDForum. Page generated in 0.04135 seconds
