Home » Language IDEs » ServerTools (WTP) » Warning: no DTD/Schema detected for the document(Why?)
Warning: no DTD/Schema detected for the document [message #719807] Mon, 29 August 2011 01:37 Go to next message
I have this xml file:
<Test label="test" name="test" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:aa="http://mydomain/Schema/AA/AA"
xmlns="http://mydomain/Schema/BB/bb"
xsi:schemaLocation="http://mydomain/Schema/schemaTest.xsd">
And I get the warning "no DTD/Schema detected for the document"
Why?
The XSD is defined...
Marco
[Updated on: Mon, 29 August 2011 01:44] by Moderator
Re: Warning: no DTD/Schema detected for the document [message #719938 is a reply to message #719807] Mon, 29 August 2011 10:20 Go to previous messageGo to next message
Are you getting any other messages about that file? As it is, it's invalid because there's no end tag for the Test start tag. That could cause the XML Validator to not be able to finish parsing (it's more strict about that than the editor) and think it never saw your attributes.
Re: Warning: no DTD/Schema detected for the document [message #719946 is a reply to message #719807] Mon, 29 August 2011 10:32 Go to previous messageGo to next message
Hi Marco,
the syntax of your schemaLocation attribute is invalid. It should map a
"xmlns" value to a URL, e.g.
xsi:schemaLocation="http://mydomain/Schema/AA/AA
This would map the namespace "aa" to a specific location.
Hope this helps
Wolfgang
Am 29.08.2011 07:37, schrieb MarcoGT:
> Why?
> Thanks
> Marco
Re: Warning: no DTD/Schema detected for the document [message #720062 is a reply to message #719938] Mon, 29 August 2011 15:26 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Mon, 29 August 2011 10:20
My error...it did not copied all the XML file, but there is the </Test> closing tag...I only get the warning about missing schema...no any others
Re: Warning: no DTD/Schema detected for the document [message #720063 is a reply to message #719946] Mon, 29 August 2011 15:27 Go to previous messageGo to next message
Wolfgang Knauf wrote on Mon, 29 August 2011 10:32
Hi Marco,
Hope this helps
Ok, I will try with this!
Thank you.
Marco
Re: Warning: no DTD/Schema detected for the document [message #720365 is a reply to message #720063] Tue, 30 August 2011 09:17 Go to previous messageGo to next message
Ok, with suggestion from Wolfgang now it works, thank you.
It is possible to disable the validation of ALL XML files inside workspace but keep validation for the opened XML file?
Re: Warning: no DTD/Schema detected for the document [message #720868 is a reply to message #720365] Wed, 31 August 2011 07:49 Go to previous message
Hi Marco,
I don't think this is possible. In the project specific properties, you
have some configuration options for the XML validator (e.g.: validate
on build or only perform manual validation), and you can declare exclude
lists. But the option you request is probably not available.
Best regards
Wolfgang
Previous Topic:weird context location
Next Topic:Default XPath View
Current Time: Sat Jul 19 19:04:29 EDT 2025
Powered by FUDForum. Page generated in 0.04427 seconds
