Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Seems that EAttributes of type EByteArray are not mapped correctly against hibernate
[Teneo] Seems that EAttributes of type EByteArray are not mapped correctly against hibernate [message #71890] Thu, 15 February 2007 14:20 Go to next message
Teneo is mapping to a Hibernate <array> mapping with byte elements - it is
thinking that the array is of some complex type.
Instead, I think this should just be using Hibernate's <binary> mapping.
The trivial workaround for this is to use the Hibernate Type annotation
like:
@Type(type="binary")
-mike
Re: [Teneo] Seems that EAttributes of type EByteArray are not mapped correctly against hibernate [message #71947 is a reply to message #71890] Thu, 15 February 2007 23:33 Go to previous message
Yes this changed after we added support for the @Lob annotation (which you can also use). The
default for a many eattribute is that it's elements are stored in a separate table to enable
querying. So byte array is currently treated as any other primitive type array.
gr. Martin
> like:
> -mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Seems that EAttributes of type EByteArray are not mapped correctly against hibernate [message #602664 is a reply to message #71890] Thu, 15 February 2007 23:33 Go to previous message
gr. Martin
> like:
> -mike
The Netherlands
Previous Topic:Why is the unique attribute of EAttribute ignored?
Next Topic:[TENEO] stackoverflow when saving a copied resource
Current Time: Sun Jul 20 18:20:28 EDT 2025
Powered by FUDForum. Page generated in 0.04046 seconds
