Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problem in Canvas Redraw
Problem in Canvas Redraw [message #717146] Fri, 19 August 2011 08:24 Go to next message
I am Loading an image to canvas. It successfully loaded.
But when I minimize the and restore back to CANVAS window, the image was lost.
Then I have to call to redraw() and repaint the image again.
Whats the reason for clearing the Canvas? Is there any FLAG to set?
Re: Problem in Canvas Redraw [message #718506 is a reply to message #717146] Wed, 24 August 2011 10:09 Go to previous messageGo to next message
I assume you're drawing the Image to the Canvas with something like
GC.drawImage(...). If so, it sounds like you're not doing it in a
SWT.Paint callback, which is where this needs to be done. For an
example of this see
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/tree/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet245.java
Another snippet that may be helpful:
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/tree/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet48.java
Grant
On 8/19/2011 8:24 AM, Balaji wrote:
> Hi
> lost.
Re: Problem in Canvas Redraw [message #719164 is a reply to message #718506] Fri, 26 August 2011 04:50 Go to previous messageGo to next message
Thanks for your reply. Hope the following code sample is same as the example you've pointed.
Sample Code:
canvas.addPaintListener(new StartScribble());
private class MYPAINT implements PaintListener {
		    public void paintControl( PaintEvent e) {
    	  	              gc.drawRectangle(100,200 ,width,height);
		      gc.dispose();
If anything is wrong in that can you please point out
Re: Problem in Canvas Redraw [message #719947 is a reply to message #719164] Mon, 29 August 2011 10:22 Go to previous messageGo to next message
In the paint listener make sure you're using the GC from the event
(e.gc), not a GC of your own (gc). Also, you cannot dispose() the GC
from the event since you did not create it.
Grant
On 8/26/2011 4:50 AM, Balaji wrote:
> Hi
> Sample Code:
> gc.dispose();
Re: Problem in Canvas Redraw [message #719971 is a reply to message #719947] Mon, 29 August 2011 11:26 Go to previous messageGo to next message
Thanks again Grant...
This time I tried in this way but the result is same.
Public GC gc;        // ADDED NEW
gc = new GC(canvas);  // ADDED NEW
                             // gc.dispose   // REMOVED
[Updated on: Mon, 29 August 2011 11:29] by Moderator
Re: Problem in Canvas Redraw [message #720180 is a reply to message #719971] Tue, 30 August 2011 00:11 Go to previous messageGo to next message
Pls refer SWT snippets,there are many examples of problems such,
for your scanario
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/plain/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet48.java
Re: Problem in Canvas Redraw [message #720195 is a reply to message #719971] Tue, 30 August 2011 01:42 Go to previous messageGo to next message
Originally posted by:
On 2011-08-29 17:26, Balaji wrote:
> Thanks again...
> Public GC gc;
> // gc.dispose
You have not really read Grant's description, which was very clear.
- Daniel Krügler
Re: Problem in Canvas Redraw [message #720398 is a reply to message #720195] Tue, 30 August 2011 10:01 Go to previous message
Thanks Daniel, Grant and Vijay
Sorry Smile
I tried the way what Grant mentioned, but still the result is same. I think I have to relook my application. Thanks again.
This an plugin application, so does it inherit any property of Base Application. Does this can be reason for this.? Because when I try to add Label with SWT.MULTI, I am getting a Vertical line (No Text is displayed)
http://www.eclipse.org/forums/index.php/m/641889/?srch=swt+label+size#msg_641889
[Updated on: Tue, 30 August 2011 11:49] by Moderator
Previous Topic:Windows 7: how to open e-mail client
Next Topic:set text input to overwrite/insert mode programatically
Current Time: Sun Jul 20 08:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.05237 seconds
