Home » Eclipse Projects » SWTBot » How to determine button is available or not
How to determine button is available or not [message #716648] Wed, 17 August 2011 21:45 Go to next message
Hi~
I want to use SWTBot as nightly automation test tool, but i encountered an issue. In our test, for some case a dialog box with 2 buttons will popup, for some case they will not popup, if dialog popups, we need click on a button and continue. Currently i tried to use if(bot.button("Yes").isVisible()) to determine whether there is dialog box or not, but WidgetNotFoundException came up, anyone knows how to handle this case?
Re: How to determine button is available or not [message #718030 is a reply to message #716648] Tue, 23 August 2011 00:46 Go to previous messageGo to next message
On 8/17/11 6:45 PM, Joanna wrote:
> Hi~
> handle this case?
For any dialogs or popup windows that come up, a good way to make sure
they have focus is to perform shell.activate() before performing any
further actions on the shell.
-- Ketan
Re: How to determine button is available or not [message #718118 is a reply to message #718030] Tue, 23 August 2011 06:08 Go to previous messageGo to next message
In addition to Ketan's advice, I think your test API/code should actually handle and discriminate both cases, but this means that in your test scenarios you know when/if the dialog will pop-up or not.
If not, i.e. if the dialog randomly pops-up during your tests (weird BTW), then you can try the following:
  • Iterates on the SWTBot shells to check if one of them is matching the pop-up dialog title. Something like the below code might work:
    String name = ...; // YOUR POP_UP DIALOG'S TITLE
    SWTBot bot = ...;
    for (SWTBotShell shell : bot.shells()) {
    if (shell.getText() != null && shell.getText().equals(name)) {
    // HANDLE CASE WHEN DIALOG POPS UP HERE
    break;
  • Catch the WidgetNotFoundException and do nothing in the catch block. I am not really in favor of this one as it will delay your test execution, plus you don't know if you enter the catch block because the dialog didn't pop-up or of another reason.
Hope this helps,
Re: How to determine button is available or not [message #721182 is a reply to message #718118] Thu, 01 September 2011 02:38 Go to previous message
Thanks Ketan and Benjamin, i will try it~
Previous Topic:Keystrokes on SWTBotShell
Next Topic:How to access to a SWTBotTreeItem CellRenderer?
Current Time: Sat Jul 19 23:44:40 EDT 2025
Powered by FUDForum. Page generated in 0.04054 seconds
