Home » Modeling » OCL » newInstance runtime error
newInstance runtime error [message #716814] Thu, 18 August 2011 10:08 Go to next message
I tried to use the dynamic EMF to create a class diagram and its instance diagram to verify an OCL invariant. When I set up the OCL invariant as follows:
// dynamically created a class diagram and its instance diagram
try{
OCL<?, EClassifier, ?, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl
= OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier, ?, ?, Constraint> helper = ocl.createOCLHelper();
// helper.setContext(bookStoreEPackage.Literals.BOOKSTORE );
Constraint oclConstraint = helper
.createInvariant("self.books->size() < 2");
Query eval = (Query) ocl.createQuery(oclConstraint);
Boolean result = (Boolean) eval.evaluate(bookstore);
} catch (Exception e)
I got runtime error at OCL.newInstance(EcoreEnvironmentFactory.INSTANCE) as follows:
Exception in thread "main" java.lang.NoClassDefFoundError: lpg/runtime/RuleAction
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
at myPackage.MyClass.<init>(MyClass.java:101)
at myPackage.MyClass.main(MyClass.java:121)
Another question, how can I set up helper.setContext(). I just created a package,
classes etc and there is no Literals in my program to dynamically created the model.
Thanks.
Will
Re: newInstance runtime error [message #716875 is a reply to message #716814] Thu, 18 August 2011 12:10 Go to previous messageGo to next message
The stack trace indicates that lpg is the first 'Eclipse' class that you
have tried to find, so I suggest a major classPath error on your part.
These are always esoteric and one of the many joys of working with Java.
I suggest checking that simpler Eclipse classes such as EClass and
OCLExpression can be constructed. I find most of the problems go away if
my project is a plugin, ratheer than native Java, since the Eclipse
tooling then writes most of the class path for me. Just remember to
'Update classpath' after using the PDE tooling to configure your project
as a plugin.
helper just wants an EObject whose eClass() is the type of self for
parsing and which is self evaluation. Any EObject will do, if you've
created a package dynamically that will do.
Ed Willink
> try{
> at
> at java.security.AccessController.doPrivileged(Native Method)
> a package,
> created the model.
> Thanks.
> Will
Re: newInstance runtime error [message #716924 is a reply to message #716875] Thu, 18 August 2011 15:28 Go to previous messageGo to next message
I can create Eclipse classes such as EClass as follows:
theCoreFactory = EcoreFactory.eINSTANCE;
bookStoreEPackage = theCoreFactory.createEPackage();
bookStoreEPackage.setNsPrefix("bookStore");
bookStoreEPackage.setNsURI("http///com.ibm.dynamic.example.bookstore.ecore");
EcorePackage theCorePackage = EcorePackage.eINSTANCE;
bookStoreEPackage.setName("BookstorePackage");
EClass bookStoreClass = theCoreFactory.createEClass();
bookStoreClass.setName("BooksStore");
EAttribute bookStoreOwner = theCoreFactory.createEAttribute();
bookStoreOwner.setName("owner");
bookStoreOwner.setEType(theCorePackage.getEString());
EAttribute bookStoreLocation = theCoreFactory.createEAttribute();
bookStoreLocation.setName("location");
bookStoreLocation.setEType(theCorePackage.getEString());
bookStoreClass.getEStructuralFeatures().add(bookStoreOwner);
bookStoreClass.getEStructuralFeatures().add(bookStoreLocation);
EClass bookClass = theCoreFactory.createEClass();
EAttribute bookName = theCoreFactory.createEAttribute();
bookName.setName("name");
bookName.setEType(theCorePackage.getEString());
EAttribute bookISBN = theCoreFactory.createEAttribute();
bookISBN.setName("isbn");
bookISBN.setEType(theCorePackage.getEInt());
bookClass.getEStructuralFeatures().add(bookName);
bookClass.getEStructuralFeatures().add(bookISBN);
EReference bookStore_Books = theCoreFactory.createEReference();
bookStore_Books.setName("books");
bookStore_Books.setEType(bookClass);
bookStore_Books.setUpperBound(EStructuralFeature.UNBOUNDED_MULTIPLICITY);
bookStore_Books.setContainment(true);
bookStoreClass.getEStructuralFeatures().add(bookStore_Books);
bookStoreEPackage.getEClassifiers().add(bookStoreClass);
bookStoreEPackage.getEClassifiers().add(bookClass);
System.out.println("Done for the BookStore Model");
So, it seems that I can create them. What I did is new a Java project and
then add those jar files related to ecore, validation, and ocl via Property -> Java Build Path -> Libraries -> Add External JARs. Since I use dynamic EMF to create
models and then check OCL constraints, I didn't create a plugin project at
the beginning...
Will
Edward Willink wrote on Thu, 18 August 2011 12:10
as a plugin.
Ed Willink
> try{
> at
> a package,
> created the model.
> Thanks.
> Will
Re: newInstance runtime error [message #716934 is a reply to message #716924] Thu, 18 August 2011 16:12 Go to previous messageGo to next message
You don't need to create a plugin project. Select a project in the
package explorer and use the PDE Tools menu option to convert to a plugin.
Plugin classpaths have transitive characterisrics, so using OCL as a
plugin gets its dependencies such as LPG automatically.
If you use a Java project you must resolve all the dependencies by hand.
So add the lpg jar file manually, once you find it.
Ed Willink
> project at
> the beginning...
> Will
>> Hi
>> you have tried to find, so I suggest a major classPath error on your
>> part. These are always esoteric and one of the many joys of working
>> with Java. I suggest checking that simpler Eclipse classes such as
>> EClass and OCLExpression can be constructed. I find most of the
>> problems go away if my project is a plugin, ratheer than native Java,
>> since the Eclipse tooling then writes most of the class path for me.
>> Just remember to 'Update classpath' after using the PDE tooling to
>> configure your project as a plugin.
>> Regards
>> Ed Willink
>> > I tried to use the dynamic EMF to create a class diagram and its >
>> instance diagram to verify an OCL invariant. When I set up the OCL >
>> > try{
>> Constraint, > EClass, EObject> ocl
>> > OCLHelper<EClassifier, ?, ?, Constraint> helper = >
>> > I got runtime error at >
>> > Exception in thread "main" java.lang.NoClassDefFoundError: >
>> > at >
>> created > a package,
>> > classes etc and there is no Literals in my program to dynamically >
>> created the model.
>> > Thanks.
>> > Will
Re: newInstance runtime error [message #716945 is a reply to message #716934] Thu, 18 August 2011 17:12 Go to previous messageGo to next message
Ed,
The problem is gone after the conversion. Now, I have another problem according to the following code:
Query eval = ocl.createQuery(oclConstraint);
I got a cast exception error
java.lang.ClassCastException: org.eclipse.ocl.internal.evaluation.QueryImpl
at myPackage.MyClass.<init>(MyClass.java:109)
at myPackage.MyClass.main(MyClass.java:124)
Then, I add Query<EClassifier, EClass, EObject> instead of Query and I got the following error message:
The type OCL.Query is not generic; it cannot be parameterized with arguments <EClassifier, EClass, EObject>
In this case which package should I import? Thanks
Will
Re: newInstance runtime error [message #716952 is a reply to message #716945] Thu, 18 August 2011 17:29 Go to previous message
Use the ocl.ecore package whenever possible since that avoids the
nightmare template argument lists.
Ed Willink
On 18/08/2011 22:12, Williams wrote:
> Ed,
> Will
Previous Topic:OCL Nightly Builds
Next Topic:Support for OCL constraints in a particular profile of UML.
Current Time: Sun Jul 20 08:04:11 EDT 2025
Powered by FUDForum. Page generated in 0.26254 seconds
