Home » Modeling » GMF (Graphical Modeling Framework) » Block resize an element
Block resize an element [message #487125] Tue, 22 September 2009 00:52 Go to next message
Hi all,
How do I prevent a component is resized?
and, How do I get the resizing of a component? for example, resize to capture the size of the component.
Josias Paes
Re: Block resize an element [message #487135 is a reply to message #487125] Tue, 22 September 2009 02:31 Go to previous messageGo to next message
you can apply minimum and maximum size in your gmfgraph on your figure.
Aurelien Pupier
Re: Block resize an element [message #487274 is a reply to message #487135] Tue, 22 September 2009 12:05 Go to previous messageGo to next message
Thanks for answering, but I've tried to do this and failed.
Other suggestions?
Josias Paes
Re: Block resize an element [message #487314 is a reply to message #487125] Tue, 22 September 2009 14:19 Go to previous messageGo to next message
Hi there,
go to your .gmfgraph file. Set property "Resize Constraint" of the affected "Node" to value "NONE".
sas
[Updated on: Tue, 22 September 2009 14:21] by Moderator
Re: Block resize an element [message #487384 is a reply to message #487314] Tue, 22 September 2009 21:01 Go to previous messageGo to next message
Thank you very much!
Re: Block resize an element [message #716409 is a reply to message #487125] Wed, 17 August 2011 06:36 Go to previous message
Can it be done somehow through Programatically
Previous Topic:Programatically adding nodes to the GMF diagram
Next Topic:Abstract Class: How to handle links defined at the abstract class level
Current Time: Sun Jul 20 12:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.04549 seconds
