Home » Modeling » EMF » Problem regarding resolving proxy of cross model reference(Problem regarding resolving proxy of cross model reference)
Problem regarding resolving proxy of cross model reference [message #715602] Sun, 14 August 2011 15:03 Go to next message
Hi ,
I have some problem regarding resolving proxies of cross emf references.Suppose class A has a cross references of class B with ecore attrributes "resolve proxies"= "false" .
1. A a = loadPersistedObject.load("C:\\LOCATION\\", "ABC");
2. System.out.println("before----------->"+a.getB().eIsProxy());
3. EObject resolveB = EcoreUtil.resolve(a.getB(), a);
4. System.out.println("after----------->"+a.getB().eIsProxy());
if i executed above code snippet i got following console output.
true.
true.
Well, in my usecase i need to achieve some thing like , after resolving proxies (means calling EcoreUtil.resolve(...)), i should get result of number 4 line within code snippet as "false", it means the proxy are resolved.
And After calling EcoreUtil.resolve(...), i can able to see the resolved object of Class B ,but "eisProxy()" still showing "true" .
Is there any ecore attribute i have to set or something else i have missed ?
Thanks in advance,
Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #715610 is a reply to message #715602] Sun, 14 August 2011 16:07 Go to previous messageGo to next message
Comments below
On 14/08/2011 12:03 PM, vaibhav wrote:
> Hi ,
Then the reference better be in the same document.
> true.
> true.
Is a.eResource().getResourceSet() != null?
> missed ?
Is it a cross document reference? Are you using absolute URIs to load
the resource?
> Thanks in advance,
> Regards,
> Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #715642 is a reply to message #715610] Sun, 14 August 2011 22:15 Go to previous messageGo to next message
Thanks Ed Merks for your reply.
Yes a.eResource().getResourceSet() is not null.
the resource?
Yes its a cross document references.Following are the xml ...
A.xml
<?xml version="1.0" encoding="ASCII"?>
<amodel:A xmlns:amodel="http:/a.ecore" name="ABC">
<b href="file:/C:/MySecondWebsite/B.xml#/"/>
</amodel:A>
B.xml
<bmodel:B xmlns:bmodel="http:/b.ecore" name="B">
<tags>tags</tags>
</bmodel:B>
Both Xmls are persisted in different document in file system.
Best Regards,
Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #715807 is a reply to message #715642] Mon, 15 August 2011 11:46 Go to previous messageGo to next message
Comments below.
> the resource?
So you need to enable proxy resolution on the "b" feature.
> A.xml
> </amodel:A>
> B.xml
> <tags>tags</tags>
> </bmodel:B>
> Best Regards,
> Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #715830 is a reply to message #715807] Mon, 15 August 2011 13:16 Go to previous messageGo to next message
Thanks Ed Merks i got it, but if i do enabled proxy resolution on the "b" feature, proxy got resolved while accessing the "b" reference from "a"(like a.getB()).Thats why i had put ecore attribute "resolving proxies"="false" on "b" feature.
Because in my use case proxy should resolved on "b" feature, as an when we trying to do it manually means when we trying to resolve using ... EObject resolveB =EcoreUtil.resolve(a.getB(), a), and after resolving
i should able to check whether proxy are resolve or not like this
So is there are some way so that i can able to achieve this manually ?
Thanks and Best Regards,
Vaibhav
(no subject) [message #715833 is a reply to message #715807] Mon, 15 August 2011 13:16 Go to previous messageGo to next message
Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #715835 is a reply to message #715830] Mon, 15 August 2011 13:27 Go to previous messageGo to next message
Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #715866 is a reply to message #715830] Mon, 15 August 2011 15:26 Go to previous messageGo to next message
Comments below.
Yes, proxies are automatically resolved.
> feature.
So you don't want proxies to resolve...
> =EcoreUtil.resolve(a.getB(), a), and after resolving i should able
The code you showed originally returns you the result of resolving the
proxy. It has no impact on the state of a. If you want a's state to
change, you'd have to call a.setB(resolveB).
Of course I have no idea why you don't want proxies to resolve
automatically.
> Vaibhav
Re: Problem regarding resolving proxy of cross model reference [message #717817 is a reply to message #715866] Mon, 22 August 2011 09:02 Go to previous messageGo to next message
Thanks for the reply,
But there is just one more issue with the setB scenario. For me to explicitly call setB() on object a, I will have to open a write transaction on Object a which is also within the scope of an eclipse editor. I do not want to make the model dirty for a read operation until and unless the user has triggered a edit for it.
The use case is that the user has expanded a tree and i need to load some data of the children without the editor being made dirty yet. Basically I don't want to make the model dirty. Is there a way to achieve this?
Vaibbhav.
Re: Problem regarding resolving proxy of cross model reference [message #717859 is a reply to message #717817] Mon, 22 August 2011 10:40 Go to previous message
Vaibbhav,
Comments below.
> editor.
Yes and as I keep saying, I have no idea why you need to do this manually.
So what's wrong with proxies that automatically resolve?
> achieve this?
Again, automatically resolving proxies seem ideal for this. Why not?
> Regards,
> Vaibbhav.
Previous Topic:Use attributes in model validation messages
Next Topic:[EMF.core] EcoreUtils.resolve() do not return the actual instance
Current Time: Sat Jul 19 08:21:03 EDT 2025
Powered by FUDForum. Page generated in 0.28771 seconds
