Home » Eclipse Projects » EGit / JGit » .git/info/exclude ?(egit does not always respect .git/info/exclude ?)
.git/info/exclude ? [message #715199] Fri, 12 August 2011 13:22 Go to next message
I have a java project that produces build artifacts that are not supposed to under version control. Some examples are .class files, typically in directories called '*classes', and certain .jar files, typically in directories called 'lib'. These are specified in info/exclude rather than .gitignore mostly because my git repository is a bridge to an SVN repository. The entries were generated by Git itself, via 'git svn show-ignore' -- I did not do them manually.
All the ignore specs work fine in command-line git: after a build, 'git status' says "nothing to commit (working directory clean)"
In egit, some work and some don't. After a build, the ones that don't work cause spurious entries in the Git Staging view, the Commit gui etc.
Example entries in info/exclude:
# /xyzzy/
/xyzzy/bootclasses
/xyzzy/testclasses
/xyzzy/classes
# /xyzzy/lib/
/xyzzy/lib/xyzzy
/xyzzy/lib/xyzzytest.jar
/xyzzy/lib/bootstrap.jar
The first three work correctly in egit, the second three do not.
Re: .git/info/exclude ? [message #715698 is a reply to message #715199] Mon, 15 August 2011 04:57 Go to previous messageGo to next message
Please file a bug for this problem
Re: .git/info/exclude ? [message #715743 is a reply to message #715698] Mon, 15 August 2011 07:20 Go to previous message
Entered as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=354722
Previous Topic:Newbie Question: How Do I Create a New Remote Branch
Next Topic:How to discard file modification
Current Time: Sun Jul 20 12:52:51 EDT 2025
Powered by FUDForum. Page generated in 0.04700 seconds
