Home » Modeling » TMF (Xtext) » How to integrate Xtext with an existing eclipse plug-in developed for a DSL?
How to integrate Xtext with an existing eclipse plug-in developed for a DSL? [message #715359] Sat, 13 August 2011 11:13 Go to next message
There is an existing Eclipse plug-in developed for a DSL which lacks code suggestion and does not provide proper errors.
I managed to build code suggestion and error identification for the DSL using Xtext separately.
How can I integrate my code with existing eclipse plug-in for the DSL and fix the issue in the current plug-in?
Thanks in advance.
Re: How to integrate Xtext with an existing eclipse plug-in developed for a DSL? [message #715363 is a reply to message #715359] Sat, 13 August 2011 11:41 Go to previous messageGo to next message
can you elaborate a bit about what you mean with "integrate"?
~Christian
Re: How to integrate Xtext with an existing eclipse plug-in developed for a DSL? [message #715369 is a reply to message #715363] Sat, 13 August 2011 12:14 Go to previous messageGo to next message
I am totally new to Xtext.
A DSL, Processing has it's own eclipse plug-in to write it's code and run them. That plug-in lacks of code suggestion.
What I want to do is add code suggestion facility to the existing plug-in.
I refered the Xtext manual and managed to create code suggestion for the syntax of Processing separately.
Now I want to integrate my code to the existing plug-in.
How can I do that, if this is not the optimal way to add code suggestions?
(no subject) [message #715372 is a reply to message #715369] Sat, 13 August 2011 12:23 Go to previous messageGo to next message
How was the original DSL/Editor implemented? With Xtext?
If not, you have to ask the provider of that plugin/technology if it is
possible to modify its behavior.
If it was done with Xtext, the easiest would naturally be to modify the
source directly. If that is not possible, you could look at launching an
editor with a different guice module (where you override the defaults).
You naturally always have the option to provide an alternative editor
for the same DSL. (Suspect there will be issues to solve if both are
done with Xtext and both register parsers).
Anyway - can you provide more information?
- henrik
On 8/13/11 6:14 PM, Harshani Nawarathna wrote:
> Thanks
Re: (no subject) [message #715379 is a reply to message #715372] Sat, 13 August 2011 12:51 Go to previous messageGo to next message
Hi Henrik,
The DSL editor is not implemented using Xtext. It is created using ANTRL and java.
What is the best way to proceed with my work?
Henrik Lindberg wrote on Sat, 13 August 2011 12:23
- henrik
Re: (no subject) [message #715386 is a reply to message #715379] Sat, 13 August 2011 13:45 Go to previous messageGo to next message
If the author of that editor did not include the ability to add proposal
providers you are out of luck.
Why not simply write a new and better editor with Xtext and use that
instead ;-)
- henrik
On 8/13/11 6:51 PM, Harshani Nawarathna wrote:
> Hi Henrik,
> and java.
>> is possible to modify its behavior.
>> the source directly. If that is not possible, you could look at
>> launching an editor with a different guice module (where you override
>> the defaults).
>> - henrik
Re: (no subject) [message #715388 is a reply to message #715386] Sat, 13 August 2011 13:56 Go to previous messageGo to next message
Hi Henrik,
yes, That is what I want to do.
I am new to Xtext and I wrote a simple editor with code suggestions using Xtext. But how can I compile and run my code? Though I managed to write the grammar for DSL I have no idea how to proceed and give it the ability of compiling and running.
Please suggest me good references to use. I am quite lost with Xtext user guide.
Thanks a lot.
Re: (no subject) [message #715392 is a reply to message #715388] Sat, 13 August 2011 14:16 Go to previous messageGo to next message
are you saying you were not able to follow the tutorials?
Alex
Re: (no subject) [message #715432 is a reply to message #715388] Sat, 13 August 2011 21:09 Go to previous messageGo to next message
Do you want to write the compiler as well, or do you already have one
and want to use it?
- henrik
On 8/13/11 7:56 PM, Harshani Nawarathna wrote:
> Hi Henrik,
> user guide.
> Thanks a lot.
Re: (no subject) [message #715508 is a reply to message #715432] Sun, 14 August 2011 04:39 Go to previous messageGo to next message
Hi henrik,
The existing plug-in has it's own pre-compiler and it uses java compiler within eclipse.
I still have no idea how it works.
Re: (no subject) [message #715588 is a reply to message #715508] Sun, 14 August 2011 13:24 Go to previous messageGo to next message
I can only hope you are not expecting us to know "the existing plugin". If you are not able to explain what *exactly* you are trying to do, it will not make sense to continue this thread (I don't see that you answered Christian's initial reply).
Making a wild guess, IXtextBuilderParticipant is what you are looking for. When the file is saved and a build of the project is invoked, you hook into that process and call the relevant code of "the existing plugin". You may have a look at the domain model example shipped with Xtext, where the builder invokes the code generation for modified model files.
Alex
Re: (no subject) [message #715673 is a reply to message #715588] Mon, 15 August 2011 02:55 Go to previous messageGo to next message
Hi Alex,
Thanks a lot for the reply. This was my reply to Cristian in this thread.
Harshani Nawarathna wrote on Sat, 13 August 2011 12:14
I am talking about Processing plug-in for eclipse, Processing is a DSL. It lacks code suggestion and does not identify errors.
I want to add that missing features to the Processing plug-in for eclipse.
I managed to implement code and error suggestion using xtext separately by referring xtext manual.
But now I have a problem in adding the functionality I have implemented externally to the existing Processing plug-in for eclipse.
I will try the steps you have mentioned.
Thanks again.
Re: (no subject) [message #715679 is a reply to message #715673] Mon, 15 August 2011 03:24 Go to previous message
I saw that *reply* but as I said, I don't really see that it is an *answer*. If I understand correctly, you have you written the Processing plugin. But how are *we* supposed to know how to add the additional functionality, if you don't tell us what exactly that functionality is and at which point in time it is to be used (e.g. "There is a compile method that is to be executed every time the user hits Enter")?
Alex
Previous Topic:Xtext 2.0.1 Fixes
Next Topic:How to replace ANTLR?
Current Time: Sat Jul 19 13:24:39 EDT 2025
Powered by FUDForum. Page generated in 1.96798 seconds
