[mwe2] Resolving platform:/plugin [message #714686] |
Thu, 11 August 2011 04:59  |
I need to resolve
platform:/plugin/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel
within my workflow.
When using CVS, I made do with a URI mapping to a relative path that
required org.eclipse.xtext.common.types to be imported as a project into
the workspace.
Since moving to GIT the relative path collapses; unless I put
org.eclipse.xtext.common.types into my GIT.
The following appears to solve the problem by allowing access to the
true plugin:
Launch with an additional parameter: --param eclipse_home=${eclipse_home}
In the workflow:
var eclipse_home
Workflow {
bean = ResourceSetImpl : resourceSet {}
bean = StandaloneSetup { resourceSet = resourceSet
platformUri = ".."
platformUri = "${eclipse_home}"
registerGeneratedEPackage =
"org.eclipse.xtext.common.types.TypesPackage"
uriMap = Mapping {
from = "platform:/plugin/org.eclipse.xtext.common.types/"
to = "platform:/resource/org.eclipse.xtext.common.types/"
Is there a better way?
Since eclipse_home is rather useful, shouldn't the MWE launcher provide
it automatically?
Perhaps StandaloneSetup should have an "eclipseHome" Property to
configure EcorePlugin's plugin map correctly.
The MWE2 documentation seems to overlook this useful parameter passing
ability.
Is it a bug that platformUri can be set twice?
Ed Willink
Re: [mwe2] Resolving platform:/plugin [message #714942 is a reply to message #714941] |
Thu, 11 August 2011 16:21   |
Hi Ed,
your are right.
Could you please file a ticket and describe your usecase, especially why
you had to use platform:/plugin instead of platform:/resource uris.
Sebastian
On 11.08.11 21:57, Ed Willink wrote:
> Hi Sebastian
> Thanks. Yes, scanClassPath solves the need to mess around with an
> eclipse_home, but it is still necessary to have
> uriMap = Mapping {
> which seems a little redundant if scanClasspath has found all the plugin
> resources.
> Regards
> Ed Willink
> On 11/08/2011 16:27, Sebastian Zarnekow wrote:
>> Hi Ed,
>> please try to set StandaloneSetup#scanClassPath to true.
>> That should take care of most of the other configuration that you did.
>> Regards,
>> Sebastian
FUDForum. Page generated in 0.03808 seconds
