Home » Modeling » TMF (Xtext) » JvmOperation and JvmField in dsl
JvmOperation and JvmField in dsl [message #714471] Wed, 10 August 2011 11:12 Go to next message
in my dsl I have following rule:
Method:
name=[jvmTypes::JvmOperation|QualifiedName]'('request=[jvmTypes::JvmType|QualifiedName]')'{'
'field:' field=[jvmTypes::JvmField|QualifiedName]
QualifiedName:
ID('.'ID)*
At runtime I got a lot of proposals for the request element (JvmType), but NO proposals for name (JvmOperation) and field (JvmField). Is my approach
completely wrong, or what did I miss?
What I want to achieve is, that I got a list of Java method proposals for name(JvmOperation) and a list of field proposals for the field (JvmField).
How can I get this to run?
Thanks in advance,
Markus
Re: JvmOperation and JvmField in dsl [message #714476 is a reply to message #714471] Wed, 10 August 2011 11:26 Go to previous messageGo to next message
Hi Markus,
there is no index for all operations or all fields easily accessible in
the jdt. Therefore I doubt that you will be able to provide field
proposals in with your approach. Consider something like
FieldReference: type=[JvmType|QualifiedName] '.' field=[JvmField];
and customize the scoping to return only the fields that are defined in
the type on the left side.
Sebastian
On 10.08.11 17:12, Markus Schindler wrote:
> Hello,
> Method:
> QualifiedName:
> ID('.'ID)*
> approach completely wrong, or what did I miss?
> (JvmField).
> Thanks in advance,
> Markus
Re: JvmOperation and JvmField in dsl [message #714654 is a reply to message #714476] Thu, 11 August 2011 03:05 Go to previous messageGo to next message
Hi Sebastian,
thanks for the quick response. Works like a charme!
Here is my scoping method. Could you please take a look on it, if that's the way to go, or could this be simpler with same Helper classes (Which I
don't know).
public IScope scope_Method_name(WebService ws, EReference ref) {
JvmType wsType = ws.getClazz().getName();
List<IEObjectDescription> descriptions = new ArrayList<IEObjectDescription>();;
if (wsType instanceof JvmGenericType) {
JvmGenericType gt = (JvmGenericType) wsType;
for (JvmMember member : gt.getMembers()) {
if (member instanceof JvmOperation) {
descriptions.add(EObjectDescription.create(QualifiedName.create(((JvmOperation) member).getSimpleName()), member));
return new SimpleScope(descriptions);
Markus
Re: JvmOperation and JvmField in dsl [message #714848 is a reply to message #714654] Thu, 11 August 2011 11:25 Go to previous message
Hi Markus,
looks good to me.
Some minor remarks:
There is EObjectDescription.create(String, EObject) which takes care of
converting the simple string to a qualified name. There is
JvmDeclaredType#getDeclaredOperations which renders your cast and the
instanceof check obsolete.
Sebastian
On 11.08.11 09:05, Markus Schindler wrote:
> Hi Sebastian,
> I don't know).
> Regards,
> Markus
Previous Topic:Xtext 2.0 plugin product installed
Next Topic:Template proposals despite "Too many constants"
Current Time: Sun Jul 20 03:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.03990 seconds
