Home » Eclipse Projects » Standard Widget Toolkit (SWT) » dynamic combo generation(swt multiple combo box generation)
dynamic combo generation [message #713282] |
Mon, 08 August 2011 05:53  |
hi,
i have string values list or array where each value indexes to few more sub values... This goes on until 5 or 6 levels may be.
my req. is to store first set of strings in combo box and when user selects each of the list element it should generate new combo with list of second elements set and when a value is selected fro second set, third set of combo should be created and so on.
where if i use selection listener to handle event of combo box, appreciate the logic for dynamic creation of the same where the number of values and levels is variable and unknown and form should also correspondingly expand for the same.
Thanks a lot in advance, pls help.
Re: dynamic combo generation [message #713899 is a reply to message #713282] |
Tue, 09 August 2011 06:37   |
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Widget;
public class SWTComboExample implements SelectionListener {
private static final String CHILD = "CHILD";
Display d;
Shell s;
private Composite top;
SWTComboExample() {
d = new Display();
s = new Shell(d);
s.setSize(250, 250);
s.setText("A Combo Example");
ScrolledComposite sc= new ScrolledComposite(s, SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER);
top = new Composite(sc, SWT.None);
sc.setContent(top);
top.setBackground(d.getSystemColor(SWT.COLOR_WHITE));
s.setLayout(new FillLayout());
top.setLayout(new RowLayout());
final Combo c = new Combo(top, SWT.READ_ONLY);
String items[] = { "Item One", "Item Two", "Item Three", "Item Four",
"Item Five" };
c.setItems(items);
c.addSelectionListener(this);
top.setSize(top.computeSize(SWT.DEFAULT, SWT.DEFAULT));
s.open();
while (!s.isDisposed()) {
if (!d.readAndDispatch())
d.sleep();
d.dispose();
public static void main(String[] argv) {
new SWTComboExample();
public void widgetDefaultSelected(SelectionEvent arg0) {
// TODO Auto-generated method stub
public void widgetSelected(SelectionEvent arg0) {
Combo parent = (Combo) arg0.widget;
Combo data = (Combo) parent.getData(CHILD);
if (data == null) {
"Item Four", "Item Five" };
c.setItems(items);
arg0.widget.setData(CHILD, c);
} else {
data.deselectAll();
removeChildren(data);
s.layout();
private void removeChildren(Combo parent) {
if (data != null) {
data.dispose();
parent.setData(CHILD, null);
Its just a hint for you...
use what ever layout you want and accordingly modify.
Re: dynamic combo generation [message #714348 is a reply to message #714295] |
Wed, 10 August 2011 07:46   |
In the below code
if (data == null) {
c.setItems(items);
} else {
data.deselectAll();
s.layout();
instead of creating new combo's on top composite create them on a new composite,
this new composite will have a row layout(verticle) and will have further coposites as parent for each combo with rowlayout(horizontal)..
this will go on recursively...
also u have modify the info in setdata accordingly.
i want u to try it,if not able to do,will help,its easy to spend time and give u the code,but u would not learn from that so try
Re: dynamic combo generation [message #715029 is a reply to message #714486] |
Fri, 12 August 2011 03:21   |
if (data == null) {
String[] temp = wholeData.get(parent.getText());
if (temp != null) {
c.setItems(temp);
} else {
data.deselectAll();
s.layout();
wholeData is a HashTable.
i tried like the same and its working but the issue here is suppose we select 1st combo input, 2nd combo pops up and when 2nd combo input selected, 3rd combo pops up, etc.. after selecting upto a point suppose if choose some other element in intermediate combo, it removes all sublevel combos except the next one... but the last combo items does not get updated.... and shows value for previous iteration only... only when we click again on top level combo, we can go again correctly
also i would like to have a label dynamically showing aggregated string of all combo texts, is that possible...?
Re: dynamic combo generation [message #716232 is a reply to message #716003] |
Tue, 16 August 2011 14:06   |
I tried to populate combo values into a vector and print tem ina button click and reset combos for next time so that again a sequence can be formed and button is clicked to print it.,.
here the problem i see is populating into vector is missing a sequence at second level (Item11) when 3rd level sequence (Item44,Item88) is changed after fully selecting lower level combos, alternatively 2 or 3 times to enable the button which enables on last combo selected.
here the final variable string printed by button click is missing the second sequence hence....
the order followed is
item1 -> item11 -> item 44 -> item22_var (button gets enabled)
then inbetween selected, item88 -> item22_var (button gets enabled at last combo selected)
then item44 -> item22_var (same enable)
then click on button and click on Yes gives sequence item1 -> item44 -> item2_var, it misses item11.
Please help....
import java.util.Enumeration;
import java.util.Hashtable;
import java.util.Vector;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.MessageBox;
public class apiIx implements SelectionListener {
Display d;
Shell s;
Hashtable<String, String[]> wholeData = new Hashtable<String, String[]>();
String[] temp = new String[] { "ITEM1" };
String items[] = { "ITEM1" };
String ITEM1[] = { "ITEM11", "ITEM22", };
//String TEMP[] = { "HI" };
String ITEM11[] = { "ITEM44", "ITEM88", };
String ITEM22[] = { "GROUP", };
String ITEM44[] = { "<ITEM22_VAR>", };
String ITEM88[] = { "<ITEM22_VAR>", };
public Button btnNewButton =null;
Vector<String> vCombo = new Vector<String>(1,1);
String lineOutput = "";
public apiIx() {
d = new Display();
s = new Shell(d);
s.setText("IX PROC TOR");
ScrolledComposite sc = new ScrolledComposite(s, SWT.H_SCROLL
sc.setContent(top);
top.setLayout(new GridLayout());
wholeData.put("ROOT", temp);
wholeData.put("ITEM1", ITEM1);
//wholeData.put("TEMP", TEMP);
wholeData.put("ITEM11", ITEM11);
wholeData.put("ITEM22", ITEM22);
wholeData.put("ITEM44", ITEM44);
wholeData.put("ITEM88", ITEM88);
c.setItems(items);
final MessageBox messageBox = new MessageBox(s, SWT.ICON_INFORMATION | SWT.YES | SWT.NO | SWT.CANCEL);
messageBox.setText("Info");
messageBox.setMessage("Save the changes for this line?");
s.setLayout(new RowLayout());
btnNewButton = new Button(s, SWT.PUSH);
btnNewButton.setEnabled(false);
btnNewButton.setText("Add to File");
btnNewButton.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
if (e.widget== btnNewButton) {
int buttonID = messageBox.open();
switch(buttonID) {
case SWT.YES:
// saves changes ...
Enumeration<String> eCombo=vCombo.elements();
while(eCombo.hasMoreElements())
lineOutput = lineOutput + " " + eCombo.nextElement();
lineOutput=lineOutput + '\n';
lineOutput=lineOutput.trim();
System.out.println(lineOutput);
c.deselectAll();
removeChildren(c,vCombo);
vCombo.removeAllElements();
case SWT.NO:
// exits here ...
break;
case SWT.CANCEL:
// does nothing ...
s.open();
d.sleep();
d.dispose();
new apiIx();
if (data == null) {
if (temp != null) {
c.setItems(temp);
vCombo.addElement(parent.getText());
} else {
btnNewButton.setEnabled(true);
} else {
data.deselectAll();
removeChildren(parent,vCombo);
if(vCombo.size()>1)
vCombo.remove(vCombo.lastElement());
parent.addSelectionListener(this);
s.layout();
private void removeChildren(Combo parent, Vector<String> vFCombo) {
if (data != null) {
removeChildren(data, vFCombo);
if(vFCombo.size()>1)
vFCombo.remove(vFCombo.size()-1);
data.dispose();
[Updated on: Tue, 16 August 2011 14:08] by Moderator
Current Time: Sat Jul 19 08:32:22 EDT 2025
Powered by FUDForum. Page generated in 0.08753 seconds
