Home » Archived » Sapphire » Custom Part Creation
Custom Part Creation [message #711551] Sat, 06 August 2011 05:34 Go to next message
Can anyone tell me how to create a custom part, I have a requirement where
I need to create a Custom Property editor which by default needs to provide
me couple labels and text controls like below
LABEL 1 : TEXT-FIELD-ONE
LABEL 2 : TEXT-FIELD-TWO
Ultimately when I save/persist the value text-field-one and text-field-two
value will be merged together as single value for the property field.
The reason for me going with content assist is that I need the two - fields
to be created automatically and in one of the fields I want to provide the
Java Content Assist feature.
Please correct me if my approach is wrong and is there any better approach
for my requirement.
~Kamesh
Re: Custom Part Creation [message #713611 is a reply to message #711551] Mon, 08 August 2011 12:46 Go to previous messageGo to next message
You can implement your own property editor by extending PropertyEditorRenderer and PropertyEditorRendererFactory classes, and then specifying that your implementation should be used like so...
<property-editor>
    <property>MyProperty</property>
    <hint>
        <name>factory</name>
        <value>MyCustomPropertyEditorFactory</value>  <!-- subject to import directives -->
    </hint>
</property-editor>
Writing a new property editor isn't easy. See various existing implementations of PropertyEditorRenderer in the framework to gauge the scope of the effort.
I think a better way to achieve this result would be to do the merging/parsing at the model level. Create two separate properties and then create custom XML binding instead of using the declarative variety. See @CustomXmlValueBinding and XmlValueBindingImpl.
- Konstantin
Re: Custom Part Creation [message #714082 is a reply to message #713611] Tue, 09 August 2011 14:50 Go to previous message
yeah i felt that difficulty ... will try your suggestion
Previous Topic:Content Assist
Next Topic:Overriding Sapphire Actions
Current Time: Sat Jul 19 12:25:09 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
