Home » Language IDEs » Java Development Tools (JDT) » Debug problem(VM doesn't return variables for method)
Debug problem [message #710741] Fri, 05 August 2011 07:11 Go to next message
Using eclipse indigo.
I have a eclipse-based product which uses JDT. Basically this product allows user to make implementation of interface. Then builds it.
Class file is then passed to jar with entry point. That jar loads the class and triggers different callbacks.
Here follows example of client's code:
import java.util.Map;
public class TestImplementor implements SomeBaseInterface{
	public void onInitParameters(Map<String, String> params) {
		System.out.println("onInitParameters: ");
		for (int s = 0; s < params.size(); s++)
			System.out.println(params.keySet().toArray()[s].toString() + ":"
					+ params.values().toArray()[s].toString());
		System.out.println();
	public void onInit(String data) {
		System.out.println("onInit");
		if (data!=null)
			System.out.println(data);
I added via extension point custom ILaunchConfigurationDelegate, which does launching in run/debug mode, which uses JDT:
IVMRunner runner = JavaRuntime.getDefaultVMInstall().getVMRunner(mode);
runner.run(runConfig, launch, monitor);
There are no problems with simple running the code.
But there are problems, when I try to debug client's code.
When code is interrupted for breakpoint in client's code, I can't see variables and expressions are not computed. To be completely accurate - I can see only method input variables and they are called like arg0, arg1.. but no information of local variables.
I start digging - so far I found that when VariableView requests input data - stackframe requests variables from method and method then asks VM, VM will return ABSENT_INFORMATION:
	 * @see com.sun.jdi.Method#variables()
	public List variables() throws AbsentInformationException {
		if (isNative() || isAbstract()) {
			throw new AbsentInformationException(JDIMessages.MethodImpl_No_local_variable_information_available_9);
		if (fVariables != null) {
			return fVariables;
		initJdwpRequest();
		try {
			ByteArrayOutputStream outBytes = new ByteArrayOutputStream();
			DataOutputStream outData = new DataOutputStream(outBytes);
			writeWithReferenceType(this, outData);
			boolean withGenericSignature= virtualMachineImpl().isJdwpVersionGreaterOrEqual(1, 5);
			int jdwpCommand= withGenericSignature ? JdwpCommandPacket.M_VARIABLE_TABLE_WITH_GENERIC : JdwpCommandPacket.M_VARIABLE_TABLE;
			JdwpReplyPacket replyPacket = requestVM(jdwpCommand, outBytes);
			switch (replyPacket.errorCode()) {
				case JdwpReplyPacket.ABSENT_INFORMATION:
					return inferArguments();
So basically VM doesn't return information for method.
Documentation says:
Generally, local variable information is not available for native or abstract methods (that is, their argument name information is not available), thus they will throw this exception.
But this method is not native and not abstract.
So why doesn't VM return information for method?
I would appreciate any help.
Re: Debug problem [message #713981 is a reply to message #710741] Tue, 09 August 2011 10:15 Go to previous messageGo to next message
You want to make sure that the class files are built with debug information. How is the class file getting built? Is it using Eclipse or javac? If you are using eclipse, make sure that under Project->Properties->Java Compiler, Class file generation has "Add Variable attributes .... " checked. If you are using javac, try passing -g option.
Re: Debug problem [message #714009 is a reply to message #713981] Tue, 09 August 2011 11:24 Go to previous message
You're absolutely right. I built clas files in a wrong way. I should have thought about this one the first place.
Thank you. I am really grateful.
Previous Topic:(no subject)
Next Topic:No AWT, SWT Wizard in Eclipse Indigo
Current Time: Sat Jul 19 09:33:03 EDT 2025
Powered by FUDForum. Page generated in 0.03020 seconds
