(bug?) AssertionFailedException in jface getTreePathFromItem [message #709450] |
Wed, 03 August 2011 19:31  |
I'm trying to link a Tree control with a drag'n'drop DragSourceAdapter subclass
The tree control is working fine and it's built in a plugin's view, I need to send data over LocalSelectionTransfer so I first converted the Tree control to a TreeViewer control and added the drag support
// Convert swt Tree to TreeViewer jface
m_treeViewer = new TreeViewer(aWSMLView.getTree());
int ops = DND.DROP_COPY | DND.DROP_MOVE;
Transfer[] transfers = new Transfer[] {
LocalSelectionTransfer.getTransfer()};
ParticipantDragAdapter drag = new ParticipantDragAdapter();
m_treeViewer.addDragSupport(ops, transfers, drag);
m_treeViewer is declared as a private TreeViewer variable in the class and no other methods touch it.
The 'ParticipantDragAdapter' is the following subclass of DragSourceAdapter
private class ParticipantDragAdapter extends DragSourceAdapter {
public void dragStart(DragSourceEvent event)
// .. code to retrieve data..
ISelection first_selection = m_treeViewer.getSelection(); // EXCEPTION IF EXECUTED
LocalSelectionTransfer.getTransfer().setSelection(m_treeViewer.getSelection()); // EXCEPTION IF EXECUTED
The problem is that every time I try to make the '.AbstractTreeViewer.getSelection()' method work, the plugin hangs the function and writes out
Quote:!ENTRY org.eclipse.ui 4 0 2011-08-04 01:12:26.734
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.jface.viewers.AbstractTreeViewer.getTreePathFromItem(AbstractTreeViewer.java:2870)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSelection(AbstractTreeViewer.java:2893)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1190)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1220)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:389)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Is this a bug or am I missing something
FUDForum. Page generated in 0.02547 seconds
