Home » Archived » Visual Editor (VE) » Can't make VE working
Can't make VE working [message #70804] Tue, 09 November 2004 12:22 Go to next message
Hi all!
I installed VE but it does't work as expected.
It is OK to select that I want to create a new Visual Class. I select
e.g. Swing>Frame and I press Finish. A new class is generated but I
can't see anything in the top window (visual editor). I cant see any
panel with widgets to drag and drop onto the application.
I can see the JavaBeans view in the left bottom corner but nothing there
and I also can't see Properties view.
Can anybody help me?
I tried to reinstall eclipse (3.0.1) then EMF-XDO-XSD SDK-2.0.1,
GEF-3.0.1 SDK e VE runtime 1.0.1.1 but it did not help.
I have JDK 5.0, Win XP Pro
Below is the content of workspace/.metadata/.log
Wenca
!SESSION XI 09, 2004 18:11:48.687
eclipse.buildId=M200409161125
java.version=1.5.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=cs_CZ
!ENTRY org.eclipse.core.runtime 4 2 XI 09, 2004 18:11:48.687
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl$NamespaceSuppor t.declarePrefix(XMLHelperImpl.java:1023)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.addPrefix(XMLHe lperImpl.java:903)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startPrefixMapping (XMLHandler.java:851)
at
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startPrefixMapping (SAXWrapper.java:64)
at com.icl.saxon.aelfred.SAXDriver.attribute(SAXDriver.java:687 )
at com.icl.saxon.aelfred.XmlParser.parseAttribute(XmlParser.jav a:1090)
at com.icl.saxon.aelfred.XmlParser.parseElement(XmlParser.java: 1005)
at com.icl.saxon.aelfred.XmlParser.parseDocument(XmlParser.java :510)
at com.icl.saxon.aelfred.XmlParser.doParse(XmlParser.java:163)
at com.icl.saxon.aelfred.SAXDriver.parse(SAXDriver.java:320)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:129)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:155)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:884)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:247)
at
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.de mandLoad(ProjectResourceSetImpl.java:69)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:262)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
at
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.ge tResource(ProjectResourceSetImpl.java:229)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$DefaultVEContributor.contributePalleteCats(JavaVisu alEditorPart.java:927)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$5.run(JavaVisualEditorPart.java:1307)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$CreateRegistry.run(JavaVisualEditorPart.java: 1298)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:48.737
!MESSAGE Error loading
file"platform:/plugin/org.eclipse.ve.jfc/overrides/javax/swing/ "
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter$1.run(BeaninfoClassAdapter.java:532)
at
org.eclipse.jem.internal.beaninfo.core.BeaninfoPlugin.applyO verrides(BeaninfoPlugin.java:493)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocTo(BeaninfoClassAdapter.java:523)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:519)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:437)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:394)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectProperties(BeaninfoClassAdapter.java:666)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEStructuralFeatures(BeaninfoClassAdapter.java:588)
at
org.eclipse.jem.java.impl.JavaClassImpl.getEStructuralFeatur es(JavaClassImpl.java:346)
at
org.eclipse.jem.java.impl.JavaClassImpl.getProperties(JavaCl assImpl.java:1243)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allProperties(BeaninfoClassAdapter.java:751)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllProperties(BeaninfoClassAdapter.java:596)
at
org.eclipse.jem.java.impl.JavaClassImpl.getAllProperties(Jav aClassImpl.java:1284)
at
org.eclipse.ve.internal.java.codegen.java.rules.ThisReferenc eRule.useInheritance(ThisReferenceRule.java:115)
at
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.create ThisIfNecessary(TypeVisitor.java:113)
at
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisitor.java:162)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:406)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:372)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:877)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:656)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1444)
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.88
file"platform:/plugin/org.eclipse.ve.jfc/overrides/java/awt/ "
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allProperties(BeaninfoClassAdapter.java:756)
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.118
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.148
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.178
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.258
!MESSAGE Error loading file"platform:/plugin/org.eclipse.jem/overrides/"
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:513)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.268
file"platform:/plugin/org.eclipse.ve.java.core/overrides/"
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.288
file"platform:/plugin/org.eclipse.jem/overrides/java/lang/"
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 XI 09, 2004 18:11:49.298
file" platform:/plugin/org.eclipse.ve.java.core/overrides/java/lan g/ "
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 XI 09, 2004 18:11:49.869
!MESSAGE Exception thrown.
!STACK 0
at
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderF actory.getExpDecoderFeature(ExpressionDecoderFactory.java:65 )
at
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderF actory.getExpDecoder(ExpressionDecoderFactory.java:97)
at
org.eclipse.ve.internal.java.codegen.model.BeanPart.setEObje ct(BeanPart.java:474)
at
org.eclipse.ve.internal.java.codegen.model.BeanPart.createEO bject(BeanPart.java:846)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaSourceTranslator.java:693)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:774)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:881)
at
at
!ENTRY org.eclipse.ve.java.core 4 0 XI 09, 2004 18:11:49.889
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
com.ibm.wtp.internal.emf.workbench.ProjectResourceSetImpl.ge tEObject(ProjectResourceSetImpl.java:152)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.rebuildPalette(JavaVisualEditorPart.java:620)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$10.run(JavaVisualEditorPart.java:1523)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Can't make VE working [message #70846 is a reply to message #70804] Tue, 09 November 2004 12:43 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Wenca wrote:
> Hi all!
> Thanks
> Wenca
> java.version=1.5.0
> !STACK 0
> at
> at
> at
> at
> at
<snip>
Hi Wenca,
It looks like your Java installation is using some strange XML parser
that is not the standard one included with Java and it's failing to
parse some XML files properly. Does com.icl.saxon.aelfred.SAXDriver
sound familiar? You may have installed an xml processing library into
the lib\ext directory of your Java installation.
- Jeff
Re: Can't make VE working [message #71008 is a reply to message #70846] Wed, 10 November 2004 03:39 Go to previous message
Yeah! Great, that's it! Thanks
Wenca
Jeff Myers wrote:
> Wenca wrote:
>> Hi all!
>> there and I also can't see Properties view.
>> Thanks
>> Wenca
>> java.version=1.5.0
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
> <snip>
> Hi Wenca,
> - Jeff
Re: Can't make VE working [message #602867 is a reply to message #70804] Tue, 09 November 2004 12:43 Go to previous message
Wenca wrote:
> Hi all!
> Thanks
> Wenca
> java.version=1.5.0
> !STACK 0
> at
> at
> at
> at
> at
<snip>
Hi Wenca,
- Jeff
Re: Can't make VE working [message #602907 is a reply to message #70846] Wed, 10 November 2004 03:39 Go to previous message
Wenca
Jeff Myers wrote:
> Wenca wrote:
>> Hi all!
>> Thanks
>> Wenca
>> java.version=1.5.0
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
> <snip>
> Hi Wenca,
> - Jeff
Previous Topic:Cannot use VE ...
Next Topic:grid snapping size
Current Time: Sat Jul 19 16:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.06084 seconds
