RSE memory leak [message #708004] |
Tue, 02 August 2011 06:28  |
I have been running RSE server using the dameon.pl perl script to start it but the available memory is rapidly decreasing. As it is almost the only application running on the dev server except a glassfish server I assume it comes from there , the available memory is decreasing at a speed of ~ 5Mb/sec !
in a few minutes the available memory goes from 1.2Gb to ... 3Mb
my O.S is a debian 5 lenny server , 2GB ram , VPS , XEN
[Updated on: Tue, 02 August 2011 06:29] by Moderator
Re: RSE memory leak [message #709127 is a reply to message #708004] |
Wed, 03 August 2011 10:15  |
When using the daemon.pl perl script, there are two things going on. There
is a java daemon (started by daemon.pl), running under root, that waits on a
port to authenticate and start a java server under a given user's ID. I
suspect that, in your case, it's not the daemon that is running into memory
problems but rather the launched server. There are cases where the server
uses a lot of memory and there are some ways to help with that but it may
depend on what you're doing. What kind of operations are you doing when the
memory is rapidly consumed?
"rupp" <forums-noreply@eclipse.org> wrote in message
news:j18isv$55r$1@news.eclipse.org...
>I have been running RSE server using the dameon.pl perl script to strat it
>but the memory is rapidly decreasing. As it is almost the only application
FUDForum. Page generated in 0.07008 seconds
