Home » Eclipse Projects » Eclipse Platform » Maven Jetty Plugin: hot deploy possible?(mvn jetty:run)
Maven Jetty Plugin: hot deploy possible? [message #703357] Wed, 27 July 2011 09:41 Go to next message
I'm running the Maven Jetty Plugin from the command line via "mvn jetty:run". Is it possible to use http:--docs.codehaus.org/display/JETTY/Hot+Deployment when running Jetty locally so I don't have to restart Jetty every time I re-compile? I don't want to set Eclipse in debug mode becuse it's really slow in that mode (with Jetty).
Re: Maven Jetty Plugin: hot deploy possible? [message #703377 is a reply to message #703357] Wed, 27 July 2011 10:06 Go to previous message
Seems like
mvn -Djetty.reload=automatic -Djetty.scanIntervalSeconds=5 jetty:run
will do the trick.
Previous Topic:Network Connections
Next Topic:Job serialization question
Current Time: Sun Jul 20 08:15:14 EDT 2025
Powered by FUDForum. Page generated in 0.04584 seconds
