Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Intro plugin
RAP Intro plugin [message #67904] Wed, 02 January 2008 04:45 Go to next message
I've found org.eclipse.rap.ui.intro in CVS, is it usable at the moment ?
Setya
Re: RAP Intro plugin [message #68025 is a reply to message #67904] Wed, 02 January 2008 10:06 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Setya,
the intro plug-in is not part of the RAP runtime. It is of coururse
usable but belongs together with ...launch, ...templates and ...help it
to the set of tooling plug-ins.
We plan to re-organize the CVS structure ([1]) to better reflect the
different parts of the project.
Rüdiger
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=201257
Setya wrote:
> Regards,
> Setya
Re: RAP Intro plugin [message #69777 is a reply to message #68025] Thu, 10 January 2008 22:48 Go to previous messageGo to next message
Rüdiger,
Thanks for your explanation above.
So in order to use it, do I always have to grab it separately from CVS or
is it possible in the future that it comes with RAP download ?
Setya
Re: RAP Intro plugin [message #69914 is a reply to message #69777] Fri, 11 January 2008 11:50 Go to previous messageGo to next message
Setya,
you *cannot* use the intro plug-in with RAP. The name may be misleading
but it is *not* the RAP adoption of org.eclipse.ui.intro.
The intro plug-in is part of the RAP Tooling which can be installed via
the update-site denoted here:
http://www.eclipse.org/rap/downloads/index.php
HTH,
Rüdiger
Setya wrote:
> Rüdiger,
>> it to the set of tooling plug-ins.
> or is it possible in the future that it comes with RAP download ?
> Regards,
> Setya
Re: RAP Intro plugin [message #70127 is a reply to message #69914] Tue, 15 January 2008 06:44 Go to previous messageGo to next message
Rüdiger,
OK, so has it been scheduled to make it usable within RAP application ?
Setya
Re: RAP Intro plugin [message #70208 is a reply to message #70127] Wed, 16 January 2008 02:21 Go to previous messageGo to next message
>> misleading but it is *not* the RAP adoption of org.eclipse.ui.intro.
>> via the update-site denoted here:
I think he means that the intro plugin is the RAP intro if you open up
you eclipse IDE. It's not part of RAP in your application and will never
be, because it is not the intro plugin.
Markus Wolf
> emedia-solutions wolf web: http://www.emedia-solutions-wolf.de
> Eimsbüttler Straße 115 mail: markus@emedia-solutions-wolf.de
> 22769 Hamburg pgp: http://wwwkeys.de.pgp.net
> +49 40 432 635 83 taxid: 57 / 126 / 16123
Re: RAP Intro plugin [message #70289 is a reply to message #70208] Wed, 16 January 2008 07:10 Go to previous messageGo to next message
When we start Eclipse IDE for the 1st time, we encounter a welcome view
that covers the whole area including toolbar. As I understand it, in RCP
this welcome view is implemented using intro plugin or am I missing
something here ?
Setya
Re: RAP Intro plugin [message #70328 is a reply to message #70289] Wed, 16 January 2008 09:32 Go to previous messageGo to next message
Setya,
you are right. In more detail, what you see is the "universal intro"
that is part of the Eclipse platform and the intro plug-in contributes
to this facility.
Rüdiger
Setya wrote:
> something here ?
> Regards,
> Setya
Re: RAP Intro plugin [message #70536 is a reply to message #70328] Thu, 17 January 2008 08:10 Go to previous messageGo to next message
Rüdiger,
> to this facility.
Basically I just want to implement the same welcome view in RAP, since I
can't use intro plugin inside my RAP app, is there any workaround for this
Setya
Re: RAP Intro plugin [message #70905 is a reply to message #70536] Mon, 21 January 2008 04:52 Go to previous messageGo to next message
Setya,
to work around the missing intro facility, you could create an
"intro"-perspective that has just one standalone view.
Within this view you could then display the welcome page, e.g. in a
browser widget.
The code for the "intro"-perspective could look like this:
class IntroPerspective implements IPerspectiveFactory {
public void createInitialLayout( IPageLayout layout ) {
layout.setEditorAreaVisible( false );
layout.addStandaloneView( "my.intro.view",
false,
IPageLayout.LEFT,
1f,
layout.getEditorArea() );
The RMS demo uses the same trick to provide an intro. Follow this link
to see what it looks like: http://rap.eclipse.org/rapdemo/rms
HTH
Rüdiger
Setya wrote:
> Rüdiger,
>> to this facility.
> this ?
> Regards,
> Setya
Re: RAP Intro plugin [message #70925 is a reply to message #70905] Mon, 21 January 2008 05:29 Go to previous messageGo to next message
Rüdiger,
> false,
> IPageLayout.LEFT,
> 1f,
Thanks for your snippet and link to the demo. I've implemented similiar to
your code above. Is is possible to also hide the toolbar as in RCP Intro ?
Setya
Re: RAP Intro plugin [message #71234 is a reply to message #70925] Wed, 23 January 2008 18:06 Go to previous messageGo to next message
Setya,
as far as I know there is no way to control whether the toolbar should
be hidden in a distinct perspective.
You could provide your own ActionBarAdvisor implementation in
WorkbenchWindowAdvisor#createActionBarAdvisor but that would affects all
perspectives.
If this is really pressing you could ask on the eclipse.platform
newsgroup if there a way to achieve this in RCP - and keep your fingers
crossed that it also works in RAP;)
Cheers
Rüdiger
Setya wrote:
> Rüdiger,
>> false,
>> IPageLayout.LEFT,
>> 1f,
> to your code above. Is is possible to also hide the toolbar as in RCP
> Intro ?
> Regards,
> Setya
Re: RAP Intro plugin (Solved) [message #76706 is a reply to message #71234] Wed, 05 March 2008 07:14 Go to previous message
Hi Rüdiger,
> perspectives.
I dig into the RCP source and found the following snippet in
ViewIntroAdapterPart class :
private void setBarVisibility(final boolean visible)
WorkbenchWindow window = (WorkbenchWindow) getSite().getWorkbenchWindow();
final boolean layout = (visible != window.getCoolBarVisible())
|| (visible != window.getPerspectiveBarVisible()); // don't layout unless
things have actually changed
if (visible)
window.setCoolBarVisible(true);
window.setPerspectiveBarVisible(true);
else
window.setCoolBarVisible(false);
window.setPerspectiveBarVisible(false);
if (layout)
window.getShell().layout();
I put the above snippet in my view's createPartControl method and the
toolbar gets hidden.
Thanks and Regards,
Setya
Previous Topic:Adjusts panel problem in Internet Explore
Next Topic:Which version of eclipse for RAP
Current Time: Sun Jul 20 10:20:18 EDT 2025
Powered by FUDForum. Page generated in 0.05237 seconds
