Home » Modeling » TMF (Xtext) » Pure ecore to Java by Xtend2(Pure ecore to Java by Xtend2)
Pure ecore to Java by Xtend2 [message #701697] Mon, 25 July 2011 09:13 Go to next message
a few days ago i started with Xtend2 to generate java code based on a pure ecore file.
I have created different Xtend2 files which are producing java code by Xtend2 richStrings. The Xtend2 files are dealing with the dyanmic emf api to access the required information.
So far everything was really easy. -> Thanks super cool Xtend2!
But right now all outputs are written to stdout console. And that is my problem!
I do not now how i can integrate a pure ecore file (no Xtext grammar exists!) into a mwe2 workflow and how to use the predefined Xtend2 files to generate code to different bundles. I'd like to invoke the generation manually (No auto compile by builders).
After browsing the web I do not have a solution yet!
I found an interesting blog post from Sebastian Zarnekow. His example seams to persist the generated output to a file using the injected extension JavaGeneratorUtils. But i could not find it. (toFileWith('''.....'''))
http://zarnekow.blogspot.com/2011/02/xtend2-whats-in-pipeline.html
Do i have to write my own Generator similar to org.eclipse.xtext.generator.Generator?
As i can remember, Xpand offered an expression called <<FILE ...>> which allowed to specify a target file that was generated inside a java package. Is there a similar access available?
Thanks a lot for your kind help,
Florian Pirchner
Re: Pure ecore to Java by Xtend2 [message #701946 is a reply to message #701697] Mon, 25 July 2011 15:10 Go to previous messageGo to next message
first two questions: do you generate from .ecore files or you you have a mymm.ecore and instances of it?
In the first case it works out of the box, in the second case you need the generated java classes for your ecore and an iresourceserice provider and it will work with the Xtext Reader and Generator component.
Or you read your models with an std reader componente (the mwe one, not the xtext) and come up with a own generator component. since you use dynamic emf this may be your choice.
The IGenerator that is used by the Generator Component that ships with Xtend has an IFileSytemAccess that allows you to generate files.
~Christian
[Updated on: Mon, 25 July 2011 15:13] by Moderator
Re: Pure ecore to Java by Xtend2 [message #701956 is a reply to message #701946] Mon, 25 July 2011 15:28 Go to previous messageGo to next message
i have an ecore called model.ecore and have generated the java classes.
The input for my generator is the EPackage of my generated ecore (ModelPackage.eINSTANCE). And then i am using the reflective emf api to access the metamodel by the contents of the package and eClasses. But i do not have instances of model.ecore like MyModel.model. I am generating code based on the metamodel.
I think the second choice of your answer would be the perfect match. Are there some examples available how to configure such a workflow? Actually i do not have an idea how to put things together.
I would try to extends the AbstractWorkflowComponent2 and configure it in a mwe2 workflow.
component = SomeReader{
component = MyModelGenerator {
Would this approach be the right way?
Thanks a lot for your answers. Very kind
Florian Pirchner
Re: Pure ecore to Java by Xtend2 [message #701969 is a reply to message #701956] Mon, 25 July 2011 15:54 Go to previous messageGo to next message
as i said before: this works out of the box
module test.Test
Workflow {
	component = org.eclipse.xtext.ecore.EcoreSupport {}
	component = org.eclipse.xtext.mwe.Reader {
		// lookup all resources on the classpath
		// useJavaClassPath = true
		// or define search scope explicitly
		path = "model"
		// this class will be generated by the xtext generator
		register = test.TestSetup {}
		loadResource = {
			slot = "model"
	component = org.eclipse.xtext.generator.GeneratorComponent {
		slot = 'model'
		outlet = {
			path = "src-gen"
package test;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xtext.ISetup;
import org.eclipse.xtext.service.AbstractGenericModule;
import com.google.inject.Guice;
import com.google.inject.Injector;
public class TestSetup implements ISetup {
	public Injector createInjectorAndDoEMFRegistration() {
		return Guice.createInjector(new AbstractGenericModule(){
			public Class<? extends ResourceSet> bindResourceSet() {
				return ResourceSetImpl.class;
			public Class<? extends org.eclipse.xtext.generator.IGenerator> bindIGenerator() {
				return test.TestGenerator.class;
package test
import org.eclipse.xtext.generator.IGenerator
import org.eclipse.xtext.generator.IFileSystemAccess
import static extension org.eclipse.xtext.xtend2.lib.ResourceExtensions.*
import org.eclipse.emf.ecore.EPackage
import org.eclipse.emf.ecore.EClass
class TestGenerator implements IGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
		for(p: resource.allContentsIterable.filter(typeof(EPackage))) {
			fsa.generateFile(p.fileName, p.compile)
	def fileName(EPackage p) {
		p.name+".txt"
	def compile(EPackage p) '''
	«FOR c : p.EClassifiers.filter(typeof(EClass))»
	class «c.name»
	«ENDFOR»
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: test.emf
Bundle-SymbolicName: test.emf
Bundle-Version: 0.1.0
Require-Bundle: org.eclipse.emf.ecore,
 org.eclipse.xtext.xbase.lib;bundle-version="2.0.0",
 org.eclipse.xtext.xtend2.lib;bundle-version="2.0.0",
 org.eclipse.xtext;bundle-version="2.0.0",
 org.eclipse.xtext.ecore;bundle-version="2.0.0",
 org.eclipse.emf.mwe2.launch;bundle-version="2.0.0",
 org.apache.log4j;bundle-version="1.2.15",
 org.apache.commons.logging;bundle-version="1.0.4"
the folder "model" contains the -ecore files to process
~Christian
[Updated on: Mon, 25 July 2011 16:11] by Moderator
Re: Pure ecore to Java by Xtend2 [message #701976 is a reply to message #701969] Mon, 25 July 2011 16:12 Go to previous message
thanks a lot!
For hours I tried different approaches but all ended up in exceptions.
Now i got the missing link. You are using the ISetup to configure the component.
You do not have to write your own generatorComponent since you configure the xtext generator component with you TestGenerator.
Sooo many thanks for you help!
Florian Pirchner
Previous Topic:Install issue
Next Topic:CustomScopingFragment in Xtext 1.0 and Maven Build
Current Time: Sun Jul 20 02:43:59 EDT 2025
Powered by FUDForum. Page generated in 0.06512 seconds
