Home » Modeling » Epsilon » [ETL] FeatureMap for Beginners
[ETL] FeatureMap for Beginners [message #699968] Fri, 22 July 2011 12:04 Go to next message
I generated an Ecore model from a schema. I am doing a transformation
from one domain model to the generated schema model. The generated model
is used in my application thus a M2T from the domain model to XML is not
an option.
I am encountering problems with the following piece of XML which is
implemented using a FeatureMap:
<value>0.001</value>
How to add the '0.001'???
In EMF code I do:
Sting value = "0.001";
ValueType valueType = cpfFactory.eINSTANCE.createValueType();
FeatureMap valueMixed = valueType.getMixed();
FeatureMapUtil.addText(valueMixed, value);
What is the equivalent in ETL/EOL?
var value = new Target!Value;
var mixed = value.mixed;
//and then what?
-H
Re: [ETL] FeatureMap for Beginners [message #701480 is a reply to message #699968] Mon, 25 July 2011 02:58 Go to previous message
On 07/22/2011 06:04 PM, Hugo A. Garcia wrote:
> Hi
> an option.
> In EMF code I do:
> //and then what?
> -H
I solved it by creating a wrapper for FeatureMapUtil and calling from
EOL as indicated in the article "Call Java from Epsilon":
http://www.eclipse.org/gmt/epsilon/doc/articles/call-java-from-epsilon/
The transformation is programmatic thus these two additional steps must
be done in addition to the steps in the article:
1) Add "org.eclipse.epsilon.eol.dt" as a plug-in dependency.
2) Add the following line of code before you parse() and execute() the
module:
etlModule.getContext().getNativeTypeDelegates().add(new
ExtensionPointToolNativeTypeDelegate());
In the transformation file you would do something like:
var text = activity.priority.asString();//Just a text property
featureMapUtilTool.addText(mixed, text);
-H
Previous Topic:[Epsilon] How can an EOL module which loads one model access to more than one ecore metamodels?
Next Topic:Replacing table row in XML file with EVL
Current Time: Sat Jul 19 12:55:09 EDT 2025
Powered by FUDForum. Page generated in 0.04608 seconds
