standalone parser and generator [message #699778] |
Fri, 22 July 2011 05:41  |
I have a maybe naive question, but I cannot find a clear answer.
Can I use Xtext to output the parser and the code generator for my grammar as a standalone software, which can be run without eclipse?
Let's say I'd like to get a .jar and give it to a friend, so that after writing his model file (with a plain text editor) he can just use java to parse the text (to check for errors) and generate code out of it.
I found similar questions on the forum, and in the FAQ, but it seems they are concerned about manipulating the model with a custom java program (please correct me if I am wrong), which is not what I want to do.
Thanks a lot
B
Re: standalone parser and generator [message #699920 is a reply to message #699888] |
Fri, 22 July 2011 11:16  |
Ed,
the "export as executable jar" (see the blog of Sebastian) is not working properly, it complains that it cannot find a class with the main() method.
But the "wrapper" class
Never the less a Wrapper (Delegate) around org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher should be a notbrainer
public class MyMwe2Launcher {
Mwe2Launcher.main(args);
is very easy and does the trick. You need to select it when creating the run configuration that you then apply to the exported jar.
Thanks Christian
FUDForum. Page generated in 0.03188 seconds
