Home » Modeling » TMF (Xtext) » standalone parser and generator
standalone parser and generator [message #699778] Fri, 22 July 2011 05:41 Go to next message
I have a maybe naive question, but I cannot find a clear answer.
Can I use Xtext to output the parser and the code generator for my grammar as a standalone software, which can be run without eclipse?
Let's say I'd like to get a .jar and give it to a friend, so that after writing his model file (with a plain text editor) he can just use java to parse the text (to check for errors) and generate code out of it.
I found similar questions on the forum, and in the FAQ, but it seems they are concerned about manipulating the model with a custom java program (please correct me if I am wrong), which is not what I want to do.
Thanks a lot
B
Re: standalone parser and generator [message #699790 is a reply to message #699778] Fri, 22 July 2011 06:07 Go to previous messageGo to next message
why shouldn't this work
In Xtext next to Generator there is a Workflow (and in Xtext 2.0 a Main class) that exactly does this)
~Christian
Re: standalone parser and generator [message #699811 is a reply to message #699790] Fri, 22 July 2011 07:11 Go to previous messageGo to next message
Yes, fine.
But I need to run the same stuff outside Eclipse, as a standalone, plain java app.
I found some useful instructions here:
http://zarnekow.blogspot.com/2010/06/how-to-deploy-xtext-standalone.html
(which however does not work.. comments say you need to provide a wrapper main class)
thank you
Re: standalone parser and generator [message #699814 is a reply to message #699811] Fri, 22 July 2011 07:15 Go to previous messageGo to next message
is standalone not what we talked about the whole thread?
The Main Class is a class Wink
There are runners for Workflows Wink
which xtext version do you use?
never the less what sebastian described in his blog should still work.
Did you have a look at the link Karsten provided in Sebastian Blog:
http://code.google.com/a/eclipselabs.org/p/lwc11-xtext/wiki/Phase_3_HeadlessGenerator
~Christian
[Updated on: Fri, 22 July 2011 07:16] by Moderator
Re: standalone parser and generator [message #699822 is a reply to message #699814] Fri, 22 July 2011 07:41 Go to previous messageGo to next message
Yes, agree, but I do not have it. I am not using Xtext 2.0
I did not even know this at the beginning; then, I had no idea of where they were, how could I use them without relying on Eclipse..
I think I am using version 1.0.2.
The link of Karsten seems not working.
The blog of Sebastian shows how to actually invoke the runner from command line, packaging all the required stuff in a jar. That is exactly what I was thinking about.
(But as said, there is a problem, it does not find the main class (see comments))
Anyway..
Thanks for your patience
B
Re: standalone parser and generator [message #699827 is a reply to message #699822] Fri, 22 July 2011 08:00 Go to previous messageGo to next message
Karsten updated his stuff to Xtext 2.0
Never the less a Wrapper (Delegate) arround org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher should be a notbrainer
public class MyMwe2Launcher {
		Mwe2Launcher.main(args);
~Christian
[Updated on: Fri, 22 July 2011 08:04] by Moderator
Re: standalone parser and generator [message #699888 is a reply to message #699811] Fri, 22 July 2011 10:28 Go to previous messageGo to next message
Bruce,
What specifically isn't working? Unless you provide details, no one
will be able to provide the information you need...
On 22/07/2011 4:11 AM, Bruce wrote:
> Yes, fine.
> plain java app.
> wrapper main class)
> thank you
Re: standalone parser and generator [message #699920 is a reply to message #699888] Fri, 22 July 2011 11:16 Go to previous message
Ed,
the "export as executable jar" (see the blog of Sebastian) is not working properly, it complains that it cannot find a class with the main() method.
But the "wrapper" class
Never the less a Wrapper (Delegate) around org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher should be a notbrainer
is very easy and does the trick. You need to select it when creating the run configuration that you then apply to the exported jar.
Thanks Christian
Previous Topic:[Xtext2/Xbase] Constructors for Entities in DomainModel example are not working
Next Topic:[Xtext] Multiple objects in one line
Current Time: Sun Jul 20 19:54:04 EDT 2025
Powered by FUDForum. Page generated in 0.04332 seconds
