i have two issue need you address [message #699773] |
Fri, 22 July 2011 05:37  |
the first issue,i have some application that wrote by swing/awt,now we need to migrate it to swt,and in previous version we use the TableModel,as you know this class support TableModelListener that can listen some events such as TableModelEvent.UPDATE,TableModelEvent.INSERT,TableModelEvent.DELETE
but in swt there is no appropriate class can replace the TableModel class,and the Table class in swt apparently don't support any listener that can listen the events previously mentioned.so far,i don't find any appropriate approach
the second issue,how can i display the html text in swt and if there is any composite that was same like the JEditorPane of swing
could anybody give me some constructive proposal about the two issue
thx~
Re: i have two issue need you address [message #700314 is a reply to message #699773] |
Sat, 23 July 2011 03:11   |
Am 22.07.11 11:37, schrieb Van:
You should use a TableViewer and if you combine that with Eclipse
Databinding which has an IObservableList (e.g. WritableList) and an
ObservableListContentProvider the table is always in sync with your model.
The Forms-Component has a control that is able to display HTML but I
don't exactly remember its name.
> thx~
FUDForum. Page generated in 0.05116 seconds
