Re: problem with birt-runtime [message #903068 is a reply to message #903037] |
Tue, 21 August 2012 15:25  |
Can you try using a shorter path? This error happens when the classpath
string is to long. Rename the location of the runtime to a shorter name.
Jason
On 8/21/2012 1:42 PM, Bala Voleti wrote:
> Hi Jason,
> I tried the to create a html file of the report, trying to use the
> genReport.
> Please find the following command which i have in my batch file.
> Set BIRT_HOME=E:\BIRTRuntime\birt-runtime-4_2_0\
> %BIRT_HOME%ReportEngine\genReport.bat -p "user='David R. Griffin'" -p
> "region=3" -f pdf E:\snapviews\Invoice_Reports\Other_Business.rptdesign
> output i receive is
> The input line is too long.
> The syntax of the command is incorrect.
> C:\Users\bvoleti\Documents\BIRT
> Can i get some help what is wrong in my command.
> Thank you,
> Bala
FUDForum. Page generated in 0.04714 seconds
