Home » Modeling » EMF » Obtain all subclasses of a class.
Obtain all subclasses of a class. [message #698919] Wed, 20 July 2011 09:23 Go to next message
Having a referenced class in an ecore model, I am trying to get all the related classes.
Getting superclasses can be done with self.eClass().eAllSuperTypes
However I am lost in finding a way to reach the subclasses (or the collection of all classes from which I can select then the subclasses based on supertype relation)
Any hint would be appreciated.
Radu.
Re: Obtain all subclasses of a class. [message #698946 is a reply to message #698919] Wed, 20 July 2011 10:08 Go to previous messageGo to next message
Radu,
Comments below.
That's just the point. There is no way to reach all the subclasses in
general, for the same reason that in Java you can't find all subclass.
I.e., it's an unbounded thing. So you'll need to find a way to reach
all the classes that interest you (i.e., determine some arbitrary set of
bounds) and from that filter out the ones that aren't subtypes.
> Radu.
Re: Obtain all subclasses of a class. [message #699017 is a reply to message #698919] Wed, 20 July 2011 12:23 Go to previous messageGo to next message
Am 20.07.2011 15:23, schrieb Radu Babota:
Not sure if that helps you but with CDO there's a special package registry implementation in the CDOSession that you use to access a model repository. This registry has a method:
public Map<EClass, List<EClass>> getSubTypes();
Maybe a look at its implementation helps you: http://dev.eclipse.org/svnroot/modeling/org.eclipse.emf.cdo/trunk/plugins/org.eclipse.emf.cdo.common/src/org/eclipse/emf/cdo/internal/common/model/CDOPackageRegistryImpl.java
Cheers
/Eike
http://www.esc-net.de
Trial and Fail in ocl... Re: Obtain all subclasses of a class. [message #699067 is a reply to message #698919] Wed, 20 July 2011 14:49 Go to previous messageGo to next message
In OCL I would expect to write:
let superClass:ecore::EClass = self.eClassRef in
ecore::EClass.allInstances()->select(subClass:ecore::EClass|superClass.isSuperTypeOf(subClass))->asOrderedSet()
However, this does not return any classes at least in a runtime
workspace, with a reference to a local ecore file.
Is this because of the registered runtime versus workspace version of ECore?
Any idea why above ocl does not return the subclasses?
Regards, Philipp
Re: Trial and Fail in ocl... Re: Obtain all subclasses of a class. [message #699118 is a reply to message #699067] Wed, 20 July 2011 17:23 Go to previous messageGo to next message
Hi Philipp
[Please use the OCL newsgroup for OCL queries.]
A distinction between runtime and compile-time EClass is certainly likely.
The whole usage of EClass is highly suspect. The new OMG-compliant pivot
model that may be used
in conjunction with the Indigo Xtext editors supports a fully reflective
oclType() so that UML's Class
and its operations can be used. It also normalises away the distinction
between runtime and compile time.
Ed Willink
> ECore?
> Regards, Philipp
Re: Obtain all subclasses of a class. [message #699739 is a reply to message #698946] Fri, 22 July 2011 04:22 Go to previous messageGo to next message
Hi Ed,
Indeed what I was looking for is to get all classes in a model.
However I have researched ways to do that (like using allInstances(), allContents(), ...) but could not reach the goal.
Here are some links
http://www.eclipse.org/forums/index.php/m/697629/
http://www.eclipse.org/forums/index.php/mv/msg/220102/695762/
http://www.eclipse.org/forums/index.php/mv/tree/21886/
However through trial and error I am able to do the task with following OCL sequence.
Probably it is not the best way but it works. Please comment if there are better ways.
(works for package and subpackages universe given a class reference pClass)
pClass.ePackage.eSubpackages->append(pClass.ePackage).eClassifiers->select(oclIsTypeOf(ecore::EClass))->select(ec:ecore::EClassifier| pClass.isSuperTypeOf(ec.oclAsType(ecore::EClass)))->asOrderedSet()
Radu
On 20/07/2011 16:08, Ed Merks wrote:
> Radu,
> Comments below.
> That's just the point. There is no way to reach all the subclasses in general, for the same reason that in Java you can't find all subclass. I.e., it's an unbounded thing. So you'll need to find a way to reach all the classes that interest you (i.e., determine some arbitrary set of bounds) and from that filter out the ones that aren't subtypes.
>> Radu.
Re: Obtain all subclasses of a class. [message #699878 is a reply to message #699739] Fri, 22 July 2011 10:14 Go to previous message
Radu,
I suppose that's all the ones in a given class's contain package's
subpackages. I'm not sure it considers the recursive subpackages
(subpackages of subpackages) or the classifiers in the same package. It
certainly won't consider classes in packages in a different containment
tree.
On 22/07/2011 1:25 AM, Radu Babota wrote:
> Hi Ed,
> Here are some links
> are better ways.
> pClass)
> Regards,
> Radu
>> Radu,
>> Comments below.
>> aren't subtypes.
>>> Radu.
Previous Topic:(no subject)
Next Topic:[CDO] org.eclipse.emf.cdo.server.hibernate: modify resource.hbm.xml settings
Current Time: Sat Jul 19 09:46:07 EDT 2025
Powered by FUDForum. Page generated in 0.05852 seconds
