Home » Language IDEs » ServerTools (WTP) » Imported schema(Does it work?)
Imported schema [message #698808] Wed, 20 July 2011 05:01 Go to next message
Hi all,
in my XML file I am using a schema called schema2.xsd.
This schema (schema2.xsd) imports a schema called schema1.xsd but when I request proposal for attribute name not all values are listed inside the box, why?
[Updated on: Wed, 20 July 2011 06:52] by Moderator
Re: Imported schema [message #698943 is a reply to message #698808] Wed, 20 July 2011 10:22 Go to previous messageGo to next message
Is the imported schema being found? Can you provide a bit more detail
about what attributes are missing. Maybe the context doesn't allow them...
On 20/07/2011 2:01 AM, MarcoGT wrote:
> Hi all,
> This schema imports a schema called schema1.xsd but when I request
> why?
Re: Imported schema [message #698955 is a reply to message #698943] Wed, 20 July 2011 10:43 Go to previous messageGo to next message
Both schemas are in the same folder.
No, the context allows the "missing attribute", I am sure of that.
Which other information do you need?
The structure is:
XML file file requires schema2.xsd
schema2.xsd has got an "import" definition with schema1.xsd
[Updated on: Wed, 20 July 2011 10:44] by Moderator
Re: Imported schema [message #698995 is a reply to message #698955] Wed, 20 July 2011 11:02 Go to previous message
Marco
Comments below.
And it's using relative imports?
You're sure the main schema is being located and used?
Are the attributes defined in the first schema being suggested?
Previous Topic:web fragments and META-INF/resources
Next Topic:"You may have mapped two namespaces with elements of the same name to the same package name&quo
Current Time: Sat Jul 19 21:30:27 EDT 2025
Powered by FUDForum. Page generated in 0.05763 seconds
