Installation of EclipseLink with Tomcat 7 [message #693092] |
Tue, 05 July 2011 15:05  |
I've tried to make work Tomcat 7 + JSF (myFaces 2) and EclipseLink with Eclipse Helios (tomcat configured and run from Eclipse also) and JDK 1.6, but I have the following problem :
- the first time i try to create an EntityManagerFactory :
emf = Persistence.createEntityManagerFactory("Bank", properties);
I get an exception.
I do this call in a session managed bean call from a web page. If I refresh the page, the call succeeds !
The exception is :
javax.faces.FacesException: Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: WebappClassLoader
context: /Bank
delegate: false
repositories:
/WEB-INF/classes/
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader@13e8d89
Internal Exception: Exception [EclipseLink-30009] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while trying to load persistence unit at url: file:/C:/WORK/DEV/Bank/EclipseWKS/Bank/WebContent/WEB-INF/classes/
Internal Exception: Exception [EclipseLink-30004] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while processing persistence.xml from URL: file:/C:/WORK/DEV/Bank/EclipseWKS/Bank/WebContent/WEB-INF/classes/
Internal Exception: java.net.MalformedURLException
at org.apache.myfaces.shared_impl.context.ExceptionHandlerImpl.wrap(ExceptionHandlerImpl.java:241)
at org.apache.myfaces.shared_impl.context.ExceptionHandlerImpl.handle(ExceptionHandlerImpl.java:156)
at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:258)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:191)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:304)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:240)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:164)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:462)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:164)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:563)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:399)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:317)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:204)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:311)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
context: /Bank
delegate: false
repositories:
/WEB-INF/classes/
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionSearchingForPersistenceResources(PersistenceUnitLoadingException.java:126)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:115)
at javax.persistence.Persistence.createEntityManagerFactory(Unknown Source)
at net.mywebsrv.bank.dao.Dao.<init>(Dao.java:29)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.apache.myfaces.config.annotation.Tomcat7AnnotationLifecycleProvider.newInstance(Tomcat7AnnotationLifecycleProvider.java:56)
at org.apache.myfaces.config.ManagedBeanBuilder.buildManagedBean(ManagedBeanBuilder.java:155)
at org.apache.myfaces.el.unified.resolver.ManagedBeanResolver.createManagedBean(ManagedBeanResolver.java:332)
at org.apache.myfaces.el.unified.resolver.ManagedBeanResolver.getValue(ManagedBeanResolver.java:295)
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:67)
at org.apache.myfaces.el.unified.resolver.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:142)
at org.apache.myfaces.el.VariableResolverImpl.resolveVariable(VariableResolverImpl.java:65)
at org.apache.myfaces.el.convert.VariableResolverToELResolver.getValue(VariableResolverToELResolver.java:116)
at org.apache.el.parser.AstIdentifier.getValue(AstIdentifier.java:71)
at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:189)
at org.apache.myfaces.el.convert.ValueExpressionToValueBinding.getValue(ValueExpressionToValueBinding.java:161)
at org.apache.myfaces.config.impl.digester.elements.ManagedProperty.getRuntimeValue(ManagedProperty.java:120)
at org.apache.myfaces.config.ManagedBeanBuilder.initializeProperties(ManagedBeanBuilder.java:321)
at org.apache.myfaces.config.ManagedBeanBuilder.buildManagedBean(ManagedBeanBuilder.java:162)
at org.apache.el.parser.AstValue.getValue(AstValue.java:147)
at org.apache.myfaces.view.facelets.el.TagValueExpression.getValue(TagValueExpression.java:85)
at javax.faces.component._DeltaStateHelper.eval(_DeltaStateHelper.java:246)
at javax.faces.component.UIData.getValue(UIData.java:1735)
at javax.faces.component.UIData.createDataModel(UIData.java:1683)
at javax.faces.component.UIData.getDataModel(UIData.java:1660)
at javax.faces.component.UIData.getRowCount(UIData.java:471)
at org.apache.myfaces.shared_impl.renderkit.html.HtmlTableRendererBase.encodeInnerHtml(HtmlTableRendererBase.java:289)
at org.apache.myfaces.shared_impl.renderkit.html.HtmlTableRendererBase.encodeChildren(HtmlTableRendererBase.java:173)
at javax.faces.component.UIComponentBase.encodeChildren(UIComponentBase.java:488)
at javax.faces.component.UIComponent.encodeAll(UIComponent.java:661)
at javax.faces.component.UIComponent.encodeAll(UIComponent.java:668)
at org.apache.myfaces.view.facelets.FaceletViewDeclarationLanguage.renderView(FaceletViewDeclarationLanguage.java:1483)
at org.apache.myfaces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:281)
at org.apache.myfaces.lifecycle.RenderResponseExecutor.execute(RenderResponseExecutor.java:85)
at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:239)
... 17 more
Caused by: Exception [EclipseLink-30009] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionLoadingFromUrl(PersistenceUnitLoadingException.java:99)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processPersistenceArchive(PersistenceUnitProcessor.java:538)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.getPersistenceUnits(PersistenceUnitProcessor.java:444)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.findPersistenceUnitInfoInArchive(JPAInitializer.java:172)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.findPersistenceUnitInfoInArchives(JPAInitializer.java:154)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.findPersistenceUnitInfo(JPAInitializer.java:135)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:73)
... 68 more
Caused by: Exception [EclipseLink-30004] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingException.exceptionProcessingPersistenceXML(PersistenceUnitLoadingException.java:117)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processPersistenceXML(PersistenceUnitProcessor.java:579)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processPersistenceArchive(PersistenceUnitProcessor.java:536)
... 73 more
Caused by: java.net.MalformedURLException
at java.net.URL.<init>(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processPersistenceXML(PersistenceUnitProcessor.java:577)
... 74 more
It seems that it searched for the META-INF/persistence.xml in the WEB-INF/classes directory, which does not exists on my installation.
If I create the 'classes' directory, i get another exception :
Internal Exception: java.io.FileNotFoundException: C:\WORK\DEV\Bank\EclipseWKS\Bank\WebContent\WEB-INF\classes
If I copy the META-INF/persistence.xml to this directory, the error disappears.
After looking at source code of JPA, it seems that two directories are searched for the persistence.xml file, but on first "not found" an exception is raised, and the second path is not searched.
Help would be appreciated.
Thanks in advance.
Re: (no subject) [message #702585 is a reply to message #698504] |
Tue, 26 July 2011 10:45  |
Bug #353121 has been submitted.
By the way, I found a workaround that does not require patching of code : I disabled the "Serve modules without publishing" of the Tomcat configuration in Eclipse.
[Updated on: Tue, 26 July 2011 10:46] by Moderator
FUDForum. Page generated in 0.09090 seconds
