Home » Archived » M2M (model-to-model transformation) » [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output
[ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #697901] Mon, 18 July 2011 06:08 Go to next message
I am experimenting with ATL these days. As far as I understood the input and the output of a transformation is an XMIResourceImpl instance. I have as input the instance of my source metamodel and I also need as output an instance of the target metamodel and not DynamicEObjectImpl instances. Is there an elegant way to do this? How can I make the conversion between DynamicEObjImpl instances and "MyModelImpl" instances?
Eszter
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698018 is a reply to message #697901] Mon, 18 July 2011 11:33 Go to previous messageGo to next message
Eszter,
As long as your models are available/registered in the package registry,
the deserializer should find a use them.
On 18/07/2011 3:08 AM, Eszter Hofmann wrote:
> Hello,
> Eszter
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698404 is a reply to message #698018] Tue, 19 July 2011 08:32 Go to previous messageGo to next message
for launching the transformation I am using the main method generated by the New > ATL Plugin Wizard.
In the method loadModels I registered my packages:
public void loadModels(String inModelPath) throws ATLCoreException {
  ModelFactory factory = new EMFModelFactory();
  ResourceSet resourceSet = factory.getResourceSet();
  Registry registry = factory.getResourceSet().getPackageRegistry();
  Map<String, Object> extMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
  extMap.put("ecore", new EcoreResourceFactoryImpl()); //$NON-NLS-1$
  extMap.put("cache", new CacheResourceFactoryImpl());
  extMap.put("om", new OMResourceFactoryImpl());
  CachePackage.eINSTANCE.eClass();
  OmPackage.eINSTANCE.eClass();
  registry.put(CachePackage.eNS_URI, CachePackage.eINSTANCE);
  registry.put(OmPackage.eNS_URI, OmPackage.eINSTANCE);
  // the generated code
  IInjector injector = new EMFInjector();
  IReferenceModel cacheMetamodel = factory.newReferenceModel();
  injector.inject(cacheMetamodel, getMetamodelUri("cache"));
  IReferenceModel omMetamodel = factory.newReferenceModel();
  injector.inject(omMetamodel, getMetamodelUri("om"));
  this.inModel = factory.newModel(cacheMetamodel);
  injector.inject(inModel, inModelPath);
  this.outModel = factory.newModel(omMetamodel);
Now loading works fine, but as result I still get DynamicEObjImpl instances.
I also tried to register my packages to the global package registry, but the result didn't change.
What else am I missing?
Eszter
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698537 is a reply to message #698404] Tue, 19 July 2011 12:08 Go to previous messageGo to next message
What's the nsURI of the model for which you're ending up with dynamic
instances, i.e., what's the value of
eObject.eClass().getEPackage().getNsURI() for the problematic
instance? Is that URI registered?
On 19/07/2011 5:32 AM, Eszter Hofmann wrote:
> instances.
> Eszter
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698932 is a reply to message #698537] Wed, 20 July 2011 09:56 Go to previous messageGo to next message
The NS_URI of the instances is http://www.eh.com/ducx/model/2011/om, same as OmPackage.eNS_URI that I used here
I also added these lines, but still no improvement:
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI("http://www.eh.com/ducx/cache"),
	URI.createFileURI("E:/workspaces/workspacemodelling/org.eclipse.m2m.atl.cachetoomplugin/Resource/cache.ecore"));
uriMap.put(URI.createURI("http://www.eh.com/ducx/model/2011/om"),
 	URI.createFileURI("E:/workspaces/workspacemodelling/org.eclipse.m2m.atl.cachetoomplugin/Resource/om.ecore"));
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #698952 is a reply to message #698932] Wed, 20 July 2011 10:13 Go to previous messageGo to next message
Eszter,
Comments below.
Set a breakpoint in XMLHandler.getPackageForURI and see why it's not
finding the package for that URI.
This is exactly the type of thing that could cause it to use a dynamic
model.
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #699294 is a reply to message #698952] Thu, 21 July 2011 05:46 Go to previous messageGo to next message
Hi Ed,
million thanks for this precious breakpoint location! I figured out a few things:
1. In my cache2om.properties file I had to use instead of the metamodel paths the nrUris, otherwise the EMFInjector replaces my OmPackageImpl and CachePackageImpl with ObjectEPackageImpl.
2. Also without all the initialization source code that I wrote in the previous posts the packages were correctly registered ... which I don't understand exactly yet.
3. The method XMLHandler.getPackageForURI method was not called at all for my http://www.eh.com/ducx/model/2011/om but in the end now I get om istances!!
So my problem is solved, but I still need to figure out a few things, otherwise I end up thinking that there is some black magic inthere Razz
Thanks a lot!
Re: [ATL] Using own model implementation instances instead of DynamicEObjImpl as in/output [message #699311 is a reply to message #699294] Thu, 21 July 2011 06:15 Go to previous message
Ok. point 2 is no black magic, I didn't delete my package registration lines.
Previous Topic:[ATL] Calling methods defined in Java in ATL transformations
Next Topic:Helper returns a sequence or set
Current Time: Sun Jul 20 06:28:25 EDT 2025
Powered by FUDForum. Page generated in 0.05036 seconds
