Home » Modeling » TMF (Xtext) » Grammar w. hundreds of message types(Standalone Java application with a grammar of hundreds of message types)
Grammar w. hundreds of message types [message #697843] Mon, 18 July 2011 03:49 Go to next message
Dear colleagues,
I'm a newbie in Xtext and currently investigating whether Xtext is suited for our use case 'Standalone Java application to parse a grammar of hundreds of message types'.
For maintaineability I would like to define every message type in a separate grammar file (.xtext file? separate project?) and finally have a grammar file that brings them all together. Is that possible, and how?
I've experimented with 'Xtext-project' for one messagedefinition and 'Xtext project from existing ecore models' to link to that message, but got lost in making the latter project reuse the grammar from the first one. I'm not even shure whether that's a suitable approach.
I didn't find a solution in the newsgroups so I start a new topic what is hopefully the right way.
Any hints are wellcome. Thanks for your cooperation.
Kind regards Franz-Josef
Re: Grammar w. hundreds of message types [message #698077 is a reply to message #697843] Mon, 18 July 2011 14:14 Go to previous messageGo to next message
do you have an existing meta model that is to be instantiated? Are you sure you need to distinguish the hundreds of message types on the grammar level?
Xtext allows only single grammar inheritance, so you'd have to have a very long chain. It might be an option to have a "dummy" grammar for every message type but combine them automatically into one (generated) grammar that is then used to build the language infrastructure.
Alex
P.S.: Modularising a language or distributing it over multiple files isn't really the first thing one would want to do with Xtext.
Re: Grammar w. hundreds of message types [message #699319 is a reply to message #698077] Thu, 21 July 2011 06:45 Go to previous message
Hi Alexander,
thanks for your reply.
I think I'll follow your advice from a different thread "... it might be a cleaner solution to have different xtext-grammars and have a (custom-self-implemented) preprocessing step that copies the rules into a combined grammar and uses that one. This is not without problems, e.g. if you have cross references to types that are not defined in the current file." (from ... index.php/t/212433/)
or
I'll split the stuff into different grammars, parse the head of my input manually to decide which grammar to feed with the rest of the input.
kind regards Franz-Josef
Previous Topic:Reuse content assist from other EMF models
Next Topic:[Xbase] Rewriting an expression to conform to expected type
Current Time: Sat Jul 19 12:54:57 EDT 2025
Powered by FUDForum. Page generated in 0.03412 seconds
