[QVTo] confused [message #696974] |
Fri, 15 July 2011 04:39  |
I created a metamodel consisting of a class called Population which contains a number of Users, Items and Matches.
The model is expected to hold Users and Items at first. Matches should be generated by the following transformation.
modeltype RZH uses Ruilen('http://ruilenzonderhuilen.com');
transformation GenerateMatches(inout mdl: RZH);
main() {
log('size:', mdl->objectsOfType(Population)->size());
log('size:', mdl->objects()[Population]->size());
log('size:', mdl.objectsOfType(Population)->size());
log('size:', mdl.objects()[Population]->size());
log('mdl', mdl);
mdl.objectsOfType(RZH::Population).map genMatches();
helper createMatch(in usr1: User, in usr2: User) : Match
log('Creating Match of ' + usr1.id + ' and' + usr2.id);
return object Match {
u1 := usr1;
u2 := usr2;
mapping inout Population::genMatches() : Population {
init {
self.matches := Set{};
population {
log('Generating matches');
self.matches := self.users -> collect(u1 | self.users->collect(u2 | createMatch(u1, u2)))
I'm having troubles understanding the behavior of the objects[], objectsOfType with and without combinations of '.' and '->'.
The model I use for testing consists of one (root) instance of Population (with a number of Users). When I run the transformation, it prints:
size:, data: 1
size:, data: 0
size:, data: 0
size:, data: 0
mdl, data: RZH - http://ruilenzonderhuilen.com
Somehow, the genMatches mapping isn't invoked at all. What am I doing wrong?
Greetings,
Wilbert.
Re: [QVTo] confused [message #697031 is a reply to message #696974] |
Fri, 15 July 2011 06:47   |
Hi Wilbert
"Somehow, the genMatches mapping isn't invoked at all. What am I doing
wrong? "
You're not using the one you found worked.
One day the specification may make the following more explicit:
object . feature => object navigation
collection -> feature => collection navigation
collection . feature => collection -> collect( feature )
object -> feature => object . oclAsSet() -> feature
OclAny::oclAsSet() => Set{ self }
OclVoid::oclAsSet() => Set{}
OclInvalid::oclAsSet() => invalid
Ed Willink
On 15/07/2011 09:39, Wilbert Alberts wrote:
> main() {
> log('mdl', mdl);
> u1 := usr1;
> u2 := usr2;
> init {
> population {
> prints:
> size:, data: 1
> size:, data: 0
> size:, data: 0
> size:, data: 0
> wrong?
> Greetings,
> Wilbert.
Re: [QVTo] confused [message #697063 is a reply to message #697031] |
Fri, 15 July 2011 08:55  |
Hi Edward,
Thanks for the explanation.
Actually the problem turned out to be something different. As I tried to deploy the metamodel in my development eclipse instance, I ended up having two versions of the meta model present: one as a plugin and one as a project. Removing the plugin (which I installed in the dropins directory) and keeping the one in the workspace solved the problem. My transformation was correct after all.
Greetings,
Wilbert.
FUDForum. Page generated in 0.03523 seconds
