Home » Eclipse Projects » Memory Analyzer » OQL query problem
OQL query problem [message #696757] Thu, 14 July 2011 15:10 Go to next message
I'm trying to list all the classes in the heap dump in a certain package, but I'm having trouble getting the query to work. Here's what I have:
SELECT getName() as name
FROM java.lang.Class
WHERE name.startsWith("com.myco")
And running it from MAT 1.1.0, I get a NullPointerException
What am I doing wrong?
Re: OQL query problem [message #696812 is a reply to message #696757] Thu, 14 July 2011 17:20 Go to previous messageGo to next message
I also tried this. Leaving off the WHERE clause lets me see which classes match, but filtering or sorting on the index column results in an internal error with the same message ("Method getName not found...")
Executed Query:
SELECT
	c AS clazz,
	c.getName() AS name,
	c.getName().indexOf("com.myco") AS index
FROM
	java.lang.Class c
WHERE
	 c.getName().indexOf("com.myco") != 0
Problem reported:
Method getName not found in object java.lang.Class [id=0x12d3d8c38]
Re: OQL query problem [message #698535 is a reply to message #696812] Tue, 19 July 2011 12:05 Go to previous messageGo to next message
Try this:
SELECT * FROM java.lang.Class c WHERE c.@getName().startsWith("com.myco")
I think you've also found a bug anyway, as Memory Analyzer should not throw a NullPointer exception whatever syntax you enter for an OQL query.
Re: OQL query problem [message #698539 is a reply to message #698535] Tue, 19 July 2011 12:14 Go to previous messageGo to next message
This also works:
SELECT * FROM java.lang.Class c WHERE c.getName().startsWith("com.myco")
Re: OQL query problem [message #698541 is a reply to message #698539] Tue, 19 July 2011 12:22 Go to previous messageGo to next message
The problem with your original query is that the string "name" is just a label for the column in the result table, not a variable, so the value "name" in the WHERE clause is not bound to any value, resulting in the NullPointerException.
Maybe this can be caught and a more informative message issued.
Re: OQL query problem [message #977819 is a reply to message #696812] Fri, 09 November 2012 10:59 Go to previous message
I think there is another bug here:
Executed Query:
SELECT
   c AS clazz,
FROM
   java.lang.Class c
WHERE
Problem reported: Method getName not found in object java.lang.Class [id=0x12d3d8c38]
I get
Problem reported:
java.lang.IllegalArgumentException
	at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Method.java:600)
	at org.eclipse.mat.parser.internal.oql.compiler.MethodCallExpression.compute(MethodCallExpression.java:107)
	at org.eclipse.mat.parser.internal.oql.compiler.PathExpression.compute(PathExpression.java:117)
	at org.eclipse.mat.parser.internal.oql.compiler.Operation$RelationalOperation.compute(Operation.java:87)
	at org.eclipse.mat.parser.internal.oql.OQLQueryImpl.accept(OQLQueryImpl.java:1035)
	at org.eclipse.mat.parser.internal.oql.OQLQueryImpl.accept(OQLQueryImpl.java:1025)
	at org.eclipse.mat.parser.internal.oql.OQLQueryImpl.filterClasses(OQLQueryImpl.java:1007)
	at org.eclipse.mat.parser.internal.oql.OQLQueryImpl.doFromItem(OQLQueryImpl.java:853)
	at org.eclipse.mat.parser.internal.oql.OQLQueryImpl.internalExecute(OQLQueryImpl.java:650)
	at org.eclipse.mat.parser.internal.oql.OQLQueryImpl.execute(OQLQueryImpl.java:627)
	at org.eclipse.mat.inspections.OQLQuery.execute(OQLQuery.java:50)
	at org.eclipse.mat.inspections.OQLQuery.execute(OQLQuery.java:1)
	at org.eclipse.mat.query.registry.ArgumentSet.execute(ArgumentSet.java:129)
	at org.eclipse.mat.ui.snapshot.panes.OQLPane$OQLJob.doRun(OQLPane.java:339)
	at org.eclipse.mat.ui.editor.AbstractPaneJob.run(AbstractPaneJob.java:34)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I'm following this up in Bugzilla 393982 OQL method invocations with overloaded methods can fail
Previous Topic:Memory Analyzer 1.2.1 is released
Next Topic:OQL enhancements
Current Time: Sun Jul 20 08:15:29 EDT 2025
Powered by FUDForum. Page generated in 0.06344 seconds
