Home » Archived » Buckminster » Howto use simple pool of bundle jars
Howto use simple pool of bundle jars [message #693302] Wed, 06 July 2011 04:32 Go to next message
hi there,
i'm realy new to the whole buckminster things and currently i'm fighting with the problem described below.
i'm working on an eclipse rcp application. this application uses several osgi bundles i either downloaded from third party sites, e.g. springsource or which where repacked by my own, e.g. hibernate stuff.
so far everything was fine. i had all the bundels beside the eclipse stuff in a dedicated project and the rcp target referenced the different folders containing bundles and features inside that project.
now i'm triing to switch over to buckminster as i want the whole thing to be build through ci, e.g. hudson and i want a proper p2 integration, and so on. now things getting difficulty to me. i have no clue how i can tell buckminster that there is a folder/location containing bundle jars. i tried - beside otheres - e.g. the url provider in my rmap and it looked quiet well. unfortunately buckminster was searching for somthing like http://path.to.my/shared/bundles/bundle.name instead of http://path.to.my/shared/bundles/bundle.name-1.0.0.201107030912.jar.
this is a bigger problem for me as the only solution i've found so far is to define other eclipse feature projects, add the bundle jars to them and export these features as p2 repositories which i then put onto my webserver thus i can use them as p2 providers in my rmap. realy complicated, isn't it?
is there a way to get buckminster just download/find the bundle jars directly from a pool/folder available either through a webserver or even better through a vcs like svn?
any help would be highly appreciated.
greez,
dirk
Re: Howto use simple pool of bundle jars [message #696360 is a reply to message #693302] Wed, 13 July 2011 15:24 Go to previous messageGo to next message
hi,
plz, anybody can help me with my problem? i can't solve it by my own...
Re: Howto use simple pool of bundle jars [message #696383 is a reply to message #693302] Wed, 13 July 2011 16:27 Go to previous messageGo to next message
Buckminster works best when it can use p2 repositories as input, second best with Maven repositories. Are the bundles in
question available on an update site somewhere or at maven central?
If not, then perhaps you should create a p2 repository of your own. It should be fairly simple.
1. Create a PDE target platform.
2. Appoint it to the folder where you have the bundles. It should be able to automatically find them and add them to
your target platform.
3. Add a feature project where you include the bundles.
4. Execute the site.p2 action in Buckminster. Now you have a p2 repository.
- thomas
On 2011-07-06 10:32, Dirk Alexander Schaefer wrote:
> hi there,
> greez,
> dirk
Re: Howto use simple pool of bundle jars [message #696551 is a reply to message #696383] Thu, 14 July 2011 05:27 Go to previous messageGo to next message
hi,
thx for the answer. that's more or less what i've done so far. i created a 'mini'-rcp-target and three different feature projects because i want their bundles to be categorized later and exported these feature projects using eclipse export functionality. i then made this repositories available over a webServer.
on my hudson i created a job that imports these features/bundels and then creates my final p2 repository which afterwards contains all the features/plugins.
well, allthough this works, it's very uncomfortable. every time i would like to, e.g. add a new bundle i have to change the rcp-target in my eclipse, add the bundle to the feature were it should go into, export that feature as p2 repository, make it available over the webServer, run the hudsonJob to create the final p2 repository and make it available over the webServer, too. that's a lot to do in order to just add one bundle.
therefore my question if there is a simpler way of getting buckminster adding bundles. but if i got you right, what i want to achieve is not possible, is it?
Re: Howto use simple pool of bundle jars [message #696587 is a reply to message #696551] Thu, 14 July 2011 06:22 Go to previous messageGo to next message
On 2011-07-14 11:27, Dirk Alexander Schaefer wrote:
> hi,
It might be possible to use the 'url' reader type with a matcher to scrape web pages where the bundles are published but
such a solution would probably require a lot of maintenance and it's not something that I'd recommend.
I'm surprised you don't find the bundles in question in a maven repository somewhere. That's usually the case. Did you
check for instance:
http://repository.springsource.com/maven/bundles/release
http://repository.springsource.com/maven/bundles/external
or the Maven Central
http://repo1.maven.org/maven2/
- thomas
Re: Howto use simple pool of bundle jars [message #696624 is a reply to message #696587] Thu, 14 July 2011 08:32 Go to previous message
hi thomas,
to be honest: no, i didn't. maybe i should... Wink so far i was looking for a general solution because i also have a dozend or so of bundels i created by my own and which are also part of the bundle pool(s) i'm talking about.
maybee it's worth to give the maven repository things a try..
thx,
dirk
Previous Topic:forth segment version (quilifier) is not replaced
Next Topic:Solutions to "Circular Component Dependency Issue with JDT"
Current Time: Sun Jul 20 12:10:22 EDT 2025
Powered by FUDForum. Page generated in 0.04288 seconds
