Help with MWE Reader [message #696359] |
Wed, 13 July 2011 15:18  |
I'm having a problem with my MWE Reader. It was working well until I did a major reorganization of my grammars and .xtetx files. This is the code with comments and questions:
public List<Table> loadTablesMwe() throws Exception {
String pathfolder = ResourcesPlugin.getWorkspace().getRoot().getProject(projectName).getLocation().toOSString();
Reader reader = new Reader();
reader.addRegister(new AGStandaloneSetup());
UriFilter filter = new UriFilter() {
public boolean matches(URI uri) {
if (uri != null) {
//I filter by file extension
if( Services.isProcedureSource(uri.toFileString()) ||
Services.isSDTSource(uri.toFileString())
return false;
return true;
reader.setUriFilter(filter);
reader.addPath(pathfolder);
SlotEntry se = new SlotEntry();
se.setSlot("tables");
//What should be here in Type? The language name? the EObject type?
se.setType("Table");
IWorkflowContext ctx = new WorkflowContextImpl();
reader.setSkipOnErrors(true);
try {
reader.invoke(ctx);
} catch(WorkflowInterruptedException e) {
System.out.println(e.getMessage());
return null;
List<Table> tables = (List<Table>) ctx.get("tables");
return tables;
I'm getting this exception:
at com.google.common.base.Preconditions.checkNotNull(Preconditions.java:180)
at com.google.common.collect.ImmutableMultimap$Builder.put(ImmutableMultimap.java:149)
at com.google.common.collect.ImmutableListMultimap$Builder.put(ImmutableListMultimap.java:161)
at com.google.common.collect.Multimaps.index(Multimaps.java:1223)
at org.eclipse.xtext.mwe.Validator.groupByURI(Validator.java:148)
at org.eclipse.xtext.mwe.Validator.appendMessages(Validator.java:121)
at org.eclipse.xtext.mwe.Validator.toString(Validator.java:104)
at org.eclipse.xtext.mwe.Validator.validate(Validator.java:88)
at org.eclipse.xtext.mwe.Reader.invokeInternal(Reader.java:165)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at altagracia.parser.XtextResourceLoader.loadTablesMwe(XtextResourceLoader.java:454)
at altagracia.plugin.popup.actions.Test.run(Test.java:35)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDelegate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3586)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3207)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
The exception is thrown at "reader.invoke(ctx);" line.
I don't know what else I can do to fix this.
I would really appreciate your help!
Thank you very much!
[Updated on: Wed, 13 July 2011 15:21] by Moderator
FUDForum. Page generated in 0.04088 seconds
