NullPointerException in LazyLinker: EPackage is null for EClass from no-namespace XML model [message #695891] |
Tue, 12 July 2011 14:59  |
Hi all,
I've been banging my head against this problem on and off for a couple of days, so I thought I run it by the community:
I have an Xtext language that has a reference to an additional external Ecore model. This model is generated from an XSD schema that describes the data format of the external model. Notably, the XML format for the external content has no namespace (it is a legacy format, and unfortunately that fact can't be helped at this point).
I got the ScopeProvider implemented that brings the external model into scope at the right places, and when I use content assist I see the correct elements from the external model. However, immediately after selecting a completion the editor reported an NPE, essentially because the model element's EClass has essentially a null EPackage. I customized the XMLHelper to set the no-namespace package and to make sure that getType(EFactory, String) works correctly and doesn't create duplicate EClasses during XML deserialization. Still, somehow the LazyLinker comes across EClasses that return null for getEPackage(), and I get the following exception:
org.eclipse.emf.common.util.WrappedException: java.lang.NullPointerException
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:65)
at org.eclipse.xtext.linking.lazy.LazyLinker.doLinkModel(LazyLinker.java:89)
at org.eclipse.xtext.linking.impl.AbstractCleaningLinker.linkModel(AbstractCleaningLinker.java:28)
at org.eclipse.xtext.resource.XtextResource.doLinking(XtextResource.java:247)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLinking(LazyLinkingResource.java:70)
at org.eclipse.xtext.resource.XtextResource.updateInternalState(XtextResource.java:213)
at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:147)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:63)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.loadResource(XtextDocumentProvider.java:120)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:103)
at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:229)
at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:735)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:131)
at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:400)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4056)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:217)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1444)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:169)
at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:149)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3043)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2600)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3061)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3088)
at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:169)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1429)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3586)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3279)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1567)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.emf.ecore.util.EcoreUtil.create(EcoreUtil.java:3247)
at org.eclipse.xtext.linking.lazy.LazyLinker.createProxy(LazyLinker.java:173)
at org.eclipse.xtext.linking.lazy.LazyLinker.createAndSetProxy(LazyLinker.java:158)
at org.eclipse.xtext.linking.lazy.LazyLinker.installProxies(LazyLinker.java:127)
at org.eclipse.xtext.linking.lazy.LazyLinker.installProxies(LazyLinker.java:109)
at org.eclipse.xtext.linking.lazy.LazyLinker$2.process(LazyLinker.java:96)
at org.eclipse.xtext.linking.lazy.LazyLinker$2.process(LazyLinker.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:63)
... 68 more
Any idea what I'm missing here? We previously integrated similar no-namespace XML models by hacking the resource loading mechanism and add a namespace on the fly, but we weren't really happy with that solution.
Mirko
Re: NullPointerException in LazyLinker: EPackage is null for EClass from no-namespace XML model [message #695933 is a reply to message #695891] |
Tue, 12 July 2011 17:24   |
Hi Mirko,
which Xtext version do you use? It looks like EReference#getType returns
a proxy which indicates a missing entry in the plugin.xml.
Can you confirm that your EPackage is available in the EPackage.Registry?
Sebastian
On 12.07.11 20:59, Mirko Raner wrote:
> Hi all,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> ... 68 more
> Mirko
FUDForum. Page generated in 0.04206 seconds
