Home » Modeling » GMF (Graphical Modeling Framework) » Problem with Indigo release
Problem with Indigo release [message #693745] |
Thu, 07 July 2011 02:42  |
running against Ganymede, my GMF editors run just fine. However, after
upgrading to Indigo (I skipped Helios), I'm running into some problems,
and regenerating doesn't help...
Pictures say more than words, so I attached a jpg showing the problem.
The node to the top is how it should look like. The node to the middle
is how it looks on Indigo. Interestingly, if I add another "entry" to
the middle compartment, the result looks like the node at the bottom -
the newly added element is now hidden, and the already existing one
shows up.
Any idea what's going on here?
Thanks a lot in advance,
Chris
Attachment: Problem.jpg
(Size: 44.30KB, Downloaded 188 times)
Re: Problem with Indigo release [message #694673 is a reply to message #693745] |
Sat, 09 July 2011 02:54   |
Hi again,
nobody?
If this is the case, can anybody maybe give me some advice on a)
possible causes for this and b) how to debug this?
Thanks in advance once again,
Chris
Am 07.07.2011 08:42, schrieb Chris:
> shows up.
> Chris
Isaac Asimov: "The most exciting phrase to hear in science, the one that
heralds new discoveries, is not 'Eureka!' but 'That's funny...'"
Re: Problem with Indigo release [message #695339 is a reply to message #694673] |
Mon, 11 July 2011 10:05  |
Ok, I've made some progress on my own. The horizontal scrollbar causes
the error. In my custom XXXCompartmentEditParts, I just override method
getFigure() like this to disable the scrollbar (which I don't need anyways):
public IFigure getFigure() {
ResizableCompartmentFigure result = (ResizableCompartmentFigure)
super.getFigure();
// workaround for a bug described here:
http://www.eclipse.org/forums/index.php/mv/tree/200734/640774/#msg_640774
result.getScrollPane().setHorizontalScrollBarVisibility(ScrollPane.NEVER);
return result;
More information can be found here:
Hope that this helps somebody...
Am 09.07.2011 08:54, schrieb Chris:
> Hi again,
> nobody?
> Chris
>> Hi,
>> shows up.
>> Chris
Wernher von Braun: "Basic research is what I am doing when I don't know
what I am doing."
Current Time: Sun Jul 20 10:52:40 EDT 2025
Powered by FUDForum. Page generated in 0.03190 seconds
