Home » Language IDEs » C / C++ IDE (CDT) » Autotools autoreconf -i problem
Autotools autoreconf -i problem [message #693409] Wed, 06 July 2011 08:20 Go to next message
I have a problem when I create a new autotools project in Indigo:
When a new project is created, I select build project but it fails saying
sh autoreconf -i
sh: Can't open autoreconf
When I call manually from terminal window 'autoreconf -i', it works.
I saw that the autoreconf is a perl script but eclipse calls it with sh.
How can I change in eclipse to call just 'autoreconf -i' or 'perl autoreconf -i'?
Edouard
Re: Autotools autoreconf -i problem [message #695189 is a reply to message #693409] Mon, 11 July 2011 04:38 Go to previous messageGo to next message
Hello Edouard.
I have the same problem you describe. To fix this I did the following in a terminal:
cd /home/myhome
mkdir bin
cd bin
ln -s /bin/bash sh
Add the new PATH at end of file bashrc:
vim /home/myhome/.bashrc
export PATH=/home/myhome/bin:$PATH
Reboot your session.
Once done this work already.
Re: Autotools autoreconf -i problem [message #695287 is a reply to message #695189] Mon, 11 July 2011 08:35 Go to previous messageGo to next message
Hi Alfred,
That works perfectly.
Thanks for the trick.
Edouard
Re: Autotools autoreconf -i problem [message #755476 is a reply to message #693409] Tue, 08 November 2011 10:49 Go to previous message
Usually it's problem with dash (or similar one) being default shell (sh) instead of bash.
On Ubuntu you can fix it with sudo dpkg-reconfigure dash, chosing No for question about becoming default shell.
Previous Topic:Trouble Installing CDT
Next Topic:Suggestions for setting up CDT in existing environment + CVS
Current Time: Sat Jul 19 19:17:40 EDT 2025
Powered by FUDForum. Page generated in 0.03795 seconds
