Home » Newcomers » Newcomers » Trouble in Debugging(When debugging Eclipse use old code, instead I clean the project)
icon9.gif  Trouble in Debugging [message #694170] Thu, 07 July 2011 21:26 Go to next message
Hello friends,
I'm having a problem in debugging in Eclipse. When I do any modification in my code and run the debugger, it "sees" as if hadn't modified the code. For example, if I write System.out.println("foo");, when running the debugger, will not be printed any message (it's like the debugger is "seeing" an old version of the code). It works only if I clean the project and restart the debugger.
I tried stopping the debugger, saving the file, rebuilding the project, but it didn't works.
Anyone knows how to fix this? It's any configuration problem?
Re: Trouble in Debugging [message #694232 is a reply to message #694170] Fri, 08 July 2011 03:03 Go to previous messageGo to next message
have you tried the project option "Build Automatically"?
greetings Lars
Re: Trouble in Debugging [message #694356 is a reply to message #694232] Fri, 08 July 2011 08:15 Go to previous messageGo to next message
Hi Lars,
Yes, this options is enabled. But it didn't work anyway.
Any other idea? Smile
Thanks for your helping.
Re: Trouble in Debugging [message #695440 is a reply to message #694356] Mon, 11 July 2011 14:25 Go to previous message
Have you tried to reinstall your eclipse ide?
Maybe this can help otherwise I have no idea.
greetings
Previous Topic:Unable to update index for central|http://repo1.maven.org/maven2
Next Topic:IllegalArgumentExcption coming from ajax code when run in my local Eclipse Helios
Current Time: Sun Jul 20 02:47:29 EDT 2025
Powered by FUDForum. Page generated in 0.07600 seconds
