ClassNotFoundException after update from M5 to M6 [message #693281] |
Wed, 06 July 2011 03:43  |
Hello everybody,
I updated from 3.0.0.M5 to 3.0.0.M6 and got some bad ClassNotFoundExceptions, when deploying the very same bundles (which are actually Snap Bundles). I.e. the same bundle works on M5, but it does not on M6, with the same configuration and libraries in /repository/usr/. Finally I decided to go back to M5. However, I think there may be a bug...
The full log file is attached.
Martin
[2011-07-06 09:32:15.018] ERROR start-signalling-5 org.springframework.web.servlet.DispatcherServlet Context initialization failed org.springframework.beans.factory.BeanDefinitionStoreException: Failed to load bean class: com.thehiddenu.ui.service.ageservice.AgeServiceController; nested exception is java.io.FileNotFoundException: class path resource [com/thehiddenu/ui/host/controller/AbstractServiceExecutionController.class] cannot be opened because it does not exist
at org.springframework.context.annotation.ConfigurationClassPostProcessor.processConfigBeanDefinitions(ConfigurationClassPostProcessor.java:195)
at org.springframework.context.annotation.ConfigurationClassPostProcessor.postProcessBeanFactory(ConfigurationClassPostProcessor.java:158)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.invokeBeanFactoryPostProcessors(AbstractDelegatedExecutionApplicationContext.java:479)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.invokeBeanFactoryPostProcessors(AbstractDelegatedExecutionApplicationContext.java:467)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.invokeBeanFactoryPostProcessors(AbstractDelegatedExecutionApplicationContext.java:395)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:407)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$301(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$1.run(AbstractDelegatedExecutionApplicationContext.java:186)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.normalRefresh(AbstractDelegatedExecutionApplicationContext.java:182)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$NoDependenciesWaitRefreshExecutor.refresh(AbstractDelegatedExecutionApplicationContext.java:89)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:175)
at org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:442)
at org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:458)
at org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:339)
at org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:306)
at org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:127)
at javax.servlet.GenericServlet.init(GenericServlet.java:244)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ServletManager$1.doWithClassLoader(ServletManager.java:71)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ServletManager$1.doWithClassLoader(ServletManager.java:1)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ManagerUtils.doWithThreadContextClassLoader(ManagerUtils.java:36)
at org.eclipse.virgo.snaps.core.internal.webapp.container.ServletManager.init(ServletManager.java:65)
at org.eclipse.virgo.snaps.core.internal.webapp.container.StandardVirtualContainer.init(StandardVirtualContainer.java:85)
at org.eclipse.virgo.snaps.core.internal.webapp.WebAppSnap.init(WebAppSnap.java:105)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.hostPublished(SnapFactoryMonitor.java:170)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.searchForExistingHost(SnapFactoryMonitor.java:288)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.registerHostListener(SnapFactoryMonitor.java:139)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.start(SnapFactoryMonitor.java:132)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor$SnapBinder.access$0(SnapFactoryMonitor.java:131)
at org.eclipse.virgo.snaps.core.internal.SnapFactoryMonitor.addingService(SnapFactoryMonitor.java:74)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:980)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:262)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:234)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:941)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:950)
at org.eclipse.virgo.snaps.core.internal.deployer.SnapLifecycleListener.createAndRegisterSnapFactoryService(SnapLifecycleListener.java:85)
at org.eclipse.virgo.snaps.core.internal.deployer.SnapLifecycleListener.onStarted(SnapLifecycleListener.java:66)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:247)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:294)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:291)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:229)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:143)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.io.FileNotFoundException: class path resource [com/thehiddenu/ui/host/controller/AbstractServiceExecutionController.class] cannot be opened because it does not exist
at org.springframework.core.io.ClassPathResource.getInputStream(ClassPathResource.java:158)
at org.springframework.core.type.classreading.SimpleMetadataReader.<init>(SimpleMetadataReader.java:45)
at org.springframework.core.type.classreading.SimpleMetadataReaderFactory.getMetadataReader(SimpleMetadataReaderFactory.java:80)
at org.springframework.core.type.classreading.CachingMetadataReaderFactory.getMetadataReader(CachingMetadataReaderFactory.java:101)
at org.springframework.core.type.classreading.SimpleMetadataReaderFactory.getMetadataReader(SimpleMetadataReaderFactory.java:76)
at org.springframework.context.annotation.ConfigurationClassParser.processConfigurationClass(ConfigurationClassParser.java:110)
at org.springframework.context.annotation.ConfigurationClassParser.parse(ConfigurationClassParser.java:85)
at org.springframework.context.annotation.ConfigurationClassPostProcessor.processConfigBeanDefinitions(ConfigurationClassPostProcessor.java:191)
... 55 common frames omitted
[2011-07-06 09:32:15.023] INFO start-signalling-5 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'com.thehiddenu.ui.service.ageservice' version '1.0.0'.
[2011-07-06 09:32:15.023] INFO start-signalling-5 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=com.thehiddenu.ui.service.ageservice_1.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=com.thehiddenu.ui.service.ageservice_1.0.0]'
[2011-07-06 09:32:15.029] ERROR iLogServiceListener@6f03de90 org.osgi.service.log.LogService Bundle org.eclipse.osgi_3.7.0.v20110224, An unexpected runtime error has occurred. org.springframework.beans.factory.BeanDefinitionStoreException: Failed to load bean class: com.thehiddenu.ui.service.ageservice.AgeServiceController; nested exception is java.io.FileNotFoundException: class path resource [com/thehiddenu/ui/host/controller/AbstractServiceExecutionController.class] cannot be opened because it does not exist
[2011-07-06 09:32:15.029] INFO iLogServiceListener@6f03de90 org.osgi.service.log.LogService Bundle com.thehiddenu.ui.service.ageservice_1.0.0, Service 297, ServiceEvent REGISTERED
[2011-07-06 09:32:15.036] ERROR iLogServiceListener@6f03de90 org.osgi.service.log.LogService Bundle org.eclipse.virgo.snaps.core_3.0.0.M06, FrameworkEvent ERROR org.springframework.beans.factory.BeanDefinitionStoreException: Failed to load bean class: com.thehiddenu.ui.service.ageservice.AgeServiceController; nested exception is java.io.FileNotFoundException: class path resource [com/thehiddenu/ui/host/controller/AbstractServiceExecutionController.class] cannot be opened because it does not exist
Attachment: log.log
(Size: 1.33MB, Downloaded 350 times)
FUDForum. Page generated in 0.10189 seconds
