osgi console problem [message #693314] |
Wed, 06 July 2011 04:53  |
I'm not sure how osgi console is organized in virgo - are there two consoles for kernel and user regions, or there is only one common console?
I've tried to put configuration osgi.console=... in org.eclipse.virgo.kernel.launch.properties and in org.eclipse.virgo.kernel.userregion.properties. Of course, I set two different ports. Only the console from the first file is opened.
And by successively executing "ss" command, the output is different: it looks like that first executions displays only user bundles, the second shows kernerl bundles, the third again user bundles...
I'm using the latest, M6 version of Virgo.
Also, vsh command generates two different outputs - one blank, and the other : "gogo: CommandNotFoundException: Command not found: vsh"
FUDForum. Page generated in 0.03257 seconds
